21607 Discussions
Driving differential clock from Cyclone III Dev Board to daugther card
I am attempting to drive a differential clock out of the Cyclone III Development Board (EP3C120F780) to the "Data Conversion HSMC" daughter card. I want to clock data to a 14-bit DAC on the daughter card. I am using the HSMC "B" connector (the "A" connector has another card on it).
I am using the ALT_OUTBUF_DIFF primitive to drive a differential LVDS clock from PLL0 on the FPGA to a differential-to-LVDS clock multiplexer (ICS854054) on the daughter card.
When I assign all of the data and clock pins on the FPGA to their corresdponding pins on the HSMC connector, I receive the following error:
Error: Pad 283 of non-differential I/O pin 'DAC[0]' in pin location AE28 is too close to pad 286 of differential I/O pin 'HSMB_CLK_OUT_P1' in pin location AD27 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
Obviously, the data lines and clock are hard wired through the daughter card, the HSMC connecter to the FPGA and I do not see a way the move the data lines away from the clock.
Am I doing this correctly? What is the best practice to output a clock from the Cyclone III to a daugther card?
Any help appreciated!
I don't exactly understand the problem. There should be no distance required between single ended and differential outputs. Distance rules only apply to differential inputs or bidirectional I/Os in relation to single ended outputs.
To implement a differential output, you don't need an ALT_OUT_BUF primitive, just assign the respective differential IO standard to the noninverted output of a differential pair.
@FvM, thanks for the reply. Are you saying that this particular distence rule is improper? In that case, how do I removed it?
Also, I am using ALT_OUTBUF_DIFF to convert from single ended clock from the PLL to differentia outputl. Is there another way to do this? Just using a NOT gate to generate one side of the differential will cause clock skew, would it not?
if you assign the single ended signal to be an LVDS output it should automatically assign the negative output
I tried removing the ALT_OUTBUF_DIFF so as to let the compiler assign the negative output. But this does not solve the problem. I still get the follow error:
Error: Pad 284 of non-differential I/O pin 'DAC[1]' in pin location AE27 is too close to pad 282 of differential I/O pin 'DAC_CLK_OUT_P' in pin location AC26 -- pads must be separated by a minimum of 5 pads. Use the Pad View of Pin Planner to debug.
I just put in a service request and I'm waiting to hear from them.
