Hola All,
this is my first attempt at a dual modulus divider. Eventually I want to use it in a Fractional_N PLL, but one step at a time. I still have to see how it holds up in a gate-level simulation. You can see part of the functional simulation below. the output follows the input when the division is set to 1 or 0. Around the 480 mark you see the pulses on Y being half that of clk, which makes sense because the division is 2 ( Num + 1), because Np1 is high. Anyway, I'm still quite the newb so if you have any suggestions let me know. http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs014.ash2/34080_10150216062425055_754135054_13088368_6268216_n.jpg
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
Entity Mod_Div_1 is
Generic(k : integer :=3);
Port(
clk : in std_logic;
Num : in Unsigned (k downto 0);
Np1 : in std_logic;
Y : out std_logic
End Mod_Div_1;
Architecture Int_N of Mod_Div_1 is
Signal Count :integer Range 0 to ((2**(k+1))-1);
Signal Y_int2 : std_logic :='0';
Begin
Y <= clk when (((Num = "00" or Num = "01") and Np1 = '0') or (Num = "00" and Np1 ='1')) else
Y_int2;
---------------- Divider code -------------------------------------
N_Divide : Process(clk)
Variable count_int : integer range 0 to ((2**(k+1))-1) :=0;
Variable Num_Val : Integer range 0 to ((2**(k+1))-1);
Variable Y_int : std_logic :='0';
Begin
Num_Val := TO_INTEGER(Num);
if (Np1 = '1') then
Num_Val := Num_Val + 1;
End if;
if(clk'EVENT and clk ='1' and (Num_Val /= 0 or Num_Val /= 1)) then
count_int := count_int + 1;
if(count_int = Num_Val) then
Y_int := '1';
count_int :=0;
Else
Y_int := '0';
End if;
if(count_int > Num) then
count_int := 0;
end if;
Y_int2 <= Y_int;
End if;
Count <= count_int;
End Process N_Divide;
End Int_N;
