21596 Discussions
Dual-port access avalon memory simulation problem
I have created an Avalon dual access on-chip memory in Qsys and tried to simulate it, with success, everything worked just fine. Then I put this module in a VHDL component, and did nothing, just led out the signals without changing. Now when I simulate it, it throws me the error message below(ERROR_1). It says that it is suppressible, so I tried to suppress it, and it returns me the error message below(ERROR_2). It is really weird, as when I look at the altsyncram component in the RTL viewer, the data_a port is clearly 32 bits wide, as should be(see picture attached). A picture of the component is also attached.
What I am trying to do is to have a memory with read and write access from one port(gonna connect it later to the PCIe megafunction), and one port with read access from the application layer. I have seen some code interfacing a memory to the application layer, but it wasn't in any way simpler than mine, and I suppose just leading out ports should work.
Tibor
ERROR_1:
# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(103): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.address_reg_b.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(104): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.byte_size.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(105): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.byteena_reg_b.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(106): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.indata_reg_b.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(107): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.init_file.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(108): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.lpm_type.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(109): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.maximum_depth.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v# ** Error (suppressible): (vsim-10000) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(110): Unresolved defparam reference to 'the_altsyncram' in the_altsyncram.numwords_a.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0 File: /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v . . .
ERROR_2
# ** Warning: (vsim-8822) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(85): - Missing Verilog connection for formal VHDL port 'rden_a'.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0/the_altsyncram File: /home/work/intelFPGA_lite/16.1/modelsim_ase/linuxaloem/../altera/vhdl/src/altera_mf/altera_mf.vhd# ** Warning: (vsim-8822) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(85): - Missing Verilog connection for formal VHDL port 'rden_b'.# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0/the_altsyncram File: /home/work/intelFPGA_lite/16.1/modelsim_ase/linuxaloem/../altera/vhdl/src/altera_mf/altera_mf.vhd# ** Fatal: (vsim-3363) /home/work/Desktop/Quartus_projects/workswell/LVDS_DESER/db/ip/temp_table/submodules/temp_table_onchip_memory2_0.v(85): The array length (1) of VHDL port 'data_a' does not match the width (32) of its Verilog connection (9th connection).# Time: 0 ps Iteration: 0 Instance: /tau2_temp_calculate_tb/tau2_temp_calculate_inst/temp_table_inst/onchip_memory2_0/the_altsyncram File: /home/work/intelFPGA_lite/16.1/modelsim_ase/linuxaloem/../altera/vhdl/src/altera_mf/altera_mf.vhd Line: 39911
The error messages indicate "missing Verilog connection for formal VHDL port." Are you missing some connections? What does the code to instantiate this look like?
Thank you for your reply, you can find the code to instantiate the component below. I do not think I left anything unconnected, as you can see on the picture attached(I unchecked the reset request option on generation).
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY work;
ENTITY tau2_temp_calculate IS
PORT( onchip_memory2_0_clk1_clk : IN STD_LOGIC;
onchip_memory2_0_s1_address : IN STD_LOGIC_VECTOR(13 DOWNTO 0);
onchip_memory2_0_s1_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
onchip_memory2_0_clk2_clk : in std_logic;
onchip_memory2_0_reset2_reset : in std_logic; -- onchip_memory2_0_reset2.reset
onchip_memory2_0_s2_address : in std_logic_vector(13 downto 0); -- onchip_memory2_0_s2.address
onchip_memory2_0_s2_chipselect : in std_logic; -- .chipselect
onchip_memory2_0_s2_clken : in std_logic; -- .clken
onchip_memory2_0_s2_write : in std_logic; -- .write
onchip_memory2_0_s2_readdata : out std_logic_vector(31 downto 0); -- .readdata
onchip_memory2_0_s2_writedata : in std_logic_vector(31 downto 0); -- .writedata
onchip_memory2_0_s2_byteenable : in std_logic_vector(3 downto 0);
onchip_memory2_0_reset1_reset : in std_logic;
onchip_memory2_0_s1_clken : in std_logic;
onchip_memory2_0_s1_chipselect : in std_logic;
onchip_memory2_0_s1_write : in std_logic;
onchip_memory2_0_s1_writedata : in std_logic_vector(31 downto 0);
onchip_memory2_0_s1_byteenable : in std_logic_vector(3 downto 0)
END tau2_temp_calculate;
ARCHITECTURE bdf_type OF tau2_temp_calculate IS
COMPONENT temp_table
port (
onchip_memory2_0_clk1_clk : in std_logic;
onchip_memory2_0_s1_address : in std_logic_vector(13 downto 0);
onchip_memory2_0_s1_readdata : out std_logic_vector(31 downto 0);
onchip_memory2_0_s1_byteenable : in std_logic_vector(3 downto 0);
END COMPONENT;
begin
temp_table_inst: temp_table
PORT MAP(
onchip_memory2_0_s1_readdata=> onchip_memory2_0_s1_readdata,
onchip_memory2_0_s1_address => onchip_memory2_0_s1_address,
onchip_memory2_0_clk1_clk=>onchip_memory2_0_clk1_clk,
onchip_memory2_0_reset1_reset=>onchip_memory2_0_reset1_reset,
onchip_memory2_0_s1_clken => onchip_memory2_0_s1_clken,
onchip_memory2_0_s1_chipselect=> onchip_memory2_0_s1_chipselect,
onchip_memory2_0_s1_write => onchip_memory2_0_s1_write,
onchip_memory2_0_s1_writedata=> onchip_memory2_0_s1_writedata,
onchip_memory2_0_s1_byteenable=> onchip_memory2_0_s1_byteenable,
onchip_memory2_0_clk2_clk =>onchip_memory2_0_clk2_clk,
onchip_memory2_0_reset2_reset => onchip_memory2_0_reset2_reset,
onchip_memory2_0_s2_address => onchip_memory2_0_s2_address,
onchip_memory2_0_s2_chipselect => onchip_memory2_0_s2_chipselect,
onchip_memory2_0_s2_clken => onchip_memory2_0_s2_clken,
onchip_memory2_0_s2_write => onchip_memory2_0_s2_write,
onchip_memory2_0_s2_readdata =>onchip_memory2_0_s2_readdata,
onchip_memory2_0_s2_writedata => onchip_memory2_0_s2_writedata,
onchip_memory2_0_s2_byteenable => onchip_memory2_0_s2_byteenable
END bdf_type;
The code for my testbench is:
LIBRARY altera_mf ;
LIBRARY ieee ;
LIBRARY std ;
USE altera_mf.all ;
USE ieee.std_logic_1164.all ;
USE ieee.std_logic_textio.all ;
USE ieee.std_logic_unsigned.all ;
use ieee.numeric_std.all;
USE std.textio.all ;
ENTITY tau2_temp_calculate_tb IS
END ;
ARCHITECTURE tau2_temp_calculate_tb_arch OF tau2_temp_calculate_tb IS
SIGNAL onchip_memory2_0_clk1_clk : STD_LOGIC;
SIGNAL onchip_memory2_0_s1_address : STD_LOGIC_VECTOR(13 DOWNTO 0);
SIGNAL onchip_memory2_0_s1_readdata : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL onchip_memory2_0_clk2_clk : std_logic;
SIGNAL onchip_memory2_0_reset2_reset : std_logic;
SIGNAL onchip_memory2_0_s2_address : std_logic_vector(13 downto 0);
SIGNAL onchip_memory2_0_s2_chipselect : std_logic;
SIGNAL onchip_memory2_0_s2_clken : std_logic;
SIGNAL onchip_memory2_0_s2_write : std_logic;
SIGNAL onchip_memory2_0_s2_readdata : std_logic_vector(31 downto 0);
SIGNAL onchip_memory2_0_s2_writedata : std_logic_vector(31 downto 0);
SIGNAL onchip_memory2_0_s2_byteenable : std_logic_vector(3 downto 0);
SIGNAL onchip_memory2_0_reset1_reset : std_logic;
SIGNAL onchip_memory2_0_s1_clken : std_logic;
SIGNAL onchip_memory2_0_s1_chipselect : std_logic;
SIGNAL onchip_memory2_0_s1_write : std_logic;
SIGNAL onchip_memory2_0_s1_writedata : std_logic_vector(31 downto 0);
SIGNAL onchip_memory2_0_s1_byteenable : std_logic_vector(3 downto 0);
COMPONENT tau2_temp_calculate
PORT(
END COMPONENT;
BEGIN
tau2_temp_calculate_inst: tau2_temp_calculate
PORT MAP(
onchip_memory2_0_clk1_clk =>onchip_memory2_0_clk1_clk,
onchip_memory2_0_s1_address =>onchip_memory2_0_s1_address,
onchip_memory2_0_clk2_clk =>'0',
onchip_memory2_0_reset2_reset=>'0',
onchip_memory2_0_s2_address=>(others => '0'),
onchip_memory2_0_s2_chipselect=>'0',
onchip_memory2_0_s2_clken=>'0',
onchip_memory2_0_s2_write=>'0',
onchip_memory2_0_s2_readdata=>onchip_memory2_0_s2_readdata,
onchip_memory2_0_s2_writedata=>(others => '0'),
onchip_memory2_0_s2_byteenable=>(others => '0'),
onchip_memory2_0_reset1_reset=>'0',
onchip_memory2_0_s1_clken => '1',
onchip_memory2_0_s1_chipselect=> '1',
onchip_memory2_0_s1_write => '0',
onchip_memory2_0_s1_writedata => "00000000000000000000000000000000",
onchip_memory2_0_s1_byteenable=> (others => '1')
Process
variable DataIN : unsigned(13 downto 0);
Begin
DataIN:=to_unsigned(0,DataIN'length);
for Z in 1 to 16383
loop
onchip_memory2_0_s1_address <= std_logic_vector(DataIN) ;
wait for 47532 ps;
DataIN:=DataIN+to_unsigned(1,DataIN'length);
end loop;
wait;
End Process;
Process
Begin
for Z in 1 to 16383
loop
onchip_memory2_0_clk1_clk <= '1' ;
wait for 23766 ps ; --"1" period:1/2*(10^12/147.27*10^6)
onchip_memory2_0_clk1_clk <= '0' ;
wait for 23766 ps ; --"0" period:1/2*(10^12/147.27*10^6)
end loop;
wait;
End Process;
END;
I think I found a possible cause for the problem. I am using Modelsim Starter Edition, my surrounding code is in VHDL, while the code generated by Qsys is in verilog. The Starter Edition for what I´ve seen does not support mixed-language simulation, so this may well be at the root of the problem. Does anyone know whether it is possible to generate the tempcalc_onchip_memory2.0.v and the functions used in it in VDHL instead of verilog? Choosing to create HDL design files for synthesis does not change this generated file.
UPDATE:
I have recreated my surrounding modules in verilog(there are some decent VHDL->verilog converters online, I chose vhd2vl), and run the simulation with those, generating the whole qsys module in verilog too. The simulation works without a problem now.
--- Quote Start ---
UPDATE:
--- Quote End ---
To fix this issue the "altera_mf_ver" library must be called before the "altera_mf" library.
For example
vsim -t ps -novopt -L altera_mf_ver -L altera_mf
