20261 Discussions
Dual-port on-chip memory for two nios communication
töz00
hello,
I implemented 2 nios processors. i want to send some calculations from one nios to other nios. so i decided to use Dual-port on-chip ram for this.
For example i want to send a simple 2 sinus calculations from one to other. How can i implement this communication with c code?
EricMunYew_C_Intel
Hi, Taha
You can implement the dual-port RAM to be one write port and one read port. One Nios write the sinus data to the write port, and the other Nios read it from the read port.
The write and read ports can be implemented by using a single clock, or separate clocks.
Please refer to below for implementation:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ram_rom.pdf
You may use pointer to the variable in the dual port RAM.
Eric
EricMunYew_C_Intel
Hi, Taha
Can we close this ?
Eric
töz00
Yes sir, i totally solved my problem. Thank you for your support​. You can close this case.
EricMunYew_C_Intel
Thanks Taha.
