Programmable Devices
21611 Discussions
Duty-cycle of PLL's input clock
Hi
I attempted to generate a 20MHz 50% duty-cycle clock from a 20MHz 25% duty-cycle clock by the PLL of FPGA. However, the result is a 40MHz 50% duty-cycle clock.
The PLL parameters are :
(1) Input clock frequency : 20MHz
(2) M/N factor : 1/1
(3) Output duty-cycle : 50%.
The FPGA is EP2S180C3. The input 20MHz 25% duty-cycle clock is LVDS signal generated by another EP2S180C3 FPGA.
In addition :
Trial 1 : The 20MHz 50% duty-cycle clock could be generated when the PLL M/N factor is 1/2.
Trial 2 : The 20MHz 50% duty-cycle clock could be generated if change the duty cycle of input 20MHz clock to 50%, while the PLL M/N factor remains being 1/1.
Trial 3 : If change the duty cycle of input 20MHz clock to 10%, still 40MHz 50% duty-cycle clock is generated by the PLL.
I think the PFD (phase frequency detector) of PLL just detects the difference of rising edge between the reference clock and feedback clock, not related with duty-cycle, is that right?
Could anyone explain it?
Sincerely
--- Quote Start ---
--- Quote End ---
Yes, presuming your measuremets are correct, most likely your input clock has ringing edges, causing double clocking.
Thank you!
Now Problem solved.
Just change the two FPGAs' clk pin I/O standard "LVDS" to "3.3-V LVTTL"
--- Quote Start ---
--- Quote End ---
I can hardly comment it without seeing the hardware and respective pin configuration related to termination and similar. I think, it's rather unlikely to get ringing edges in a correctly wired and terminated LVDS link.
