Hi
I attempted to generate a 20MHz 50% duty-cycle clock from a 20MHz 25% duty-cycle clock by the PLL of FPGA. However, the result is a 40MHz 50% duty-cycle clock. The PLL parameters are : (1) Input clock frequency : 20MHz (2) M/N factor : 1/1 (3) Output duty-cycle : 50%. The FPGA is EP2S180C3. The input 20MHz 25% duty-cycle clock is LVDS signal generated by another EP2S180C3 FPGA. In addition : Trial 1 : The 20MHz 50% duty-cycle clock could be generated when the PLL M/N factor is 1/2. Trial 2 : The 20MHz 50% duty-cycle clock could be generated if change the duty cycle of input 20MHz clock to 50%, while the PLL M/N factor remains being 1/1. Trial 3 : If change the duty cycle of input 20MHz clock to 10%, still 40MHz 50% duty-cycle clock is generated by the PLL. I think the PFD (phase frequency detector) of PLL just detects the difference of rising edge between the reference clock and feedback clock, not related with duty-cycle, is that right? Could anyone explain it? SincerelyLink Copied
--- Quote Start --- I think the PFD (phase frequency detector) of PLL just detects the difference of rising edge between the reference clock and feedback clock, not related with duty-cycle, is that right? --- Quote End --- Yes, presuming your measuremets are correct, most likely your input clock has ringing edges, causing double clocking.
Thank you!
Now Problem solved. Just change the two FPGAs' clk pin I/O standard "LVDS" to "3.3-V LVTTL" Could anyone explain it? Thanks- Mark as New
--- Quote Start --- Just change the two FPGAs' clk pin I/O standard "LVDS" to "3.3-V LVTTL" Could anyone explain it? --- Quote End --- I can hardly comment it without seeing the hardware and respective pin configuration related to termination and similar. I think, it's rather unlikely to get ringing edges in a correctly wired and terminated LVDS link.
