21602 Discussions
EMIF parameters for running DDR4 at DDR 800 rate
BKB
I am working on a design with DDR4 EMIF. The parameters are stock speed bin DDR1600 parameters. But the controller is run at DDR800.
There are two instances of the EMIF in the design. One of the instances passes calibration while the other fails calibration with the same settings.
I don't know whether its the EMIF parameters or the board issue. Please suggest the changes in the EMIF parameters to run DDR4 at DDR800.
Bharat
AdzimZM_Intel
Hi Bharat,
Can you provide the EMIF IP setting and memory datasheet for checking the IP parameter?
Which device that you used?
Which Quartus version that you used?
Adzim
BKB
Hi Adzim,
I have attached the snips of the IP configuration as its not allowed to upload  .ip files.  If there is an email I can send it to, please let me know. The current RDIMM is MTA36ASF2G72PZ – 16GB with its base part MT40A1G4.
The FPAG part is 1SG10MHN3F74C2LG. This is a dual die FPGA and the same design is across both the die. Each design has two DDR4 EMIF interfaces. All the 4 interfaces use the same IP.
I started with Quartus Pro 21.2, updated to Quartus Pro 22.3 and now Quartus Pro 22.4. When I started, one controller would calibrate and other would not in each die. With some board parameter changes, both the controllers calibrate in die U1 while in die U1 one controller calibrates and one does not.
This is the primary issue.
Beyond this, I want to increase the size to 64 GB but when I increase the size to 64GB (add address bit mem_a[17]) the implementation fails for pin assignment and Quartus suggests the exact same pin for both the controllers (in each die).
I tried to come up with a 32GB implementation to access 32GB out of the 64GB module. As RAS is shared with a[16] the implementation goes through. I tied the 18th address bit (a[17] to '0'). This implementation does not pass calibration.
So the another issue is how to access 32GB out of the 64GB.
And finally get a pinout for 64GB for board re-spin.
Please let me know if I can provide any further information.
Bharat
BKB
Hi Adzim,
Please find attached the snippet of EMIF settings.
Bharat
AdzimZM_Intel
Hi Bharat,
Thank you for your feedback.
I have checked the IP parameter and the setting is okay.
Can you check if there any timing violation in the "Report DDR" section inside the Compilation Report?
Since there is only one interface that is failing, can you try to swap the RDIMM at the fails interface with working interface?
Can you run an EMIF example design in the fails interface? Using similar pin placement of the fails interface with just one interface in the design.
Adzim
AdzimZM_Intel
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
