21615 Discussions
EP4CE30F23 Fast Parallel Programming
According to the Cyclone IV Device Handbook (http://www.altera.com/literature/hb/cyclone-iv/cyiv-51008.pdf), "FPP configuration is supported in ... all Cyclone IV E devices" (excluding the E144 package). However, when trying to convert my SOF into an RBF using "Convert Programming Files" in Quartus II 14.0.2 Build 209, I get an error:
"Device EP4CE30F23 does not supprot Passive Parallel x8 scheme"
All I can get to work is to select "1-bit Passive Serial". Is there a difference in the RBF output when selecting the different modes?
Dont think have difference since RBF only contains the config bitstream..no header.if u hv time u can try compare between PS and FPPx8 RBF generated in other quartus version.
Use older Quartus II version such as v13.0 or v13.1 to generated programming file in FPP mode. It seems that's a Quartus II bug, better submit a SR to report the error.
can use QII13.1 to generate rbf and try again. I didn't heard there is bug for this question in QII14.0.
