21616 Discussions
Problems with Cyclone II and Quartus 13.0.0.156
I downloaded Quartus II 13.0.0 build 156 which is the last versions that supports Cyclone II. Since I downloaded the Web Edition I also downloaded the Cyclone II and Cyclone V families to use on it.
When I tried to add both devices, Quartus didn't recongnize Cyclone II file.
http://www.alteraforum.com/forum/attachment.php?attachmentid=9495&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=9496&stc=1
I added two pictures showing the problem and the file that I downloaded.
Can anybody help me?
AFAIK only 13.0 subscription edition supports CII. Starting from 13.1 CII is removed permanently.
did you install Cyclone II device? you should install device also.
