I have a cyclone IV GX linked with an EPCS 16 in AS mode. I would like to store 2 conf files (factory+user) and use remote mode. EPCS16 seems to be too small to store 2sof converted in jic, even with compression activated. I would like to avoid EPCS64 if possible. So is there a way to reduce file size ? maybe for small design ? Thanks !Link Copied
Quarts don't fit into pint pots!
Maybe make the 'factory' image only contain enough logic to write the 'user' one?- Mark as New
I know but epcs16 was enough for cyclone III :-/
sof file have always the same size. even with a few logic element (900LE << 1%) it doesn't fit.- Mark as New
I'm no expert, but I'd have thought compression would help.
thanks but without compression I can't even store 1 sof=>jic in epcs16. compression allows to store 1 but not 2.
It would be great to have a chapter in each device handbook which explain what you can do with each epcs.- Mark as New
Actually the FPGA handbook each have a configuration chapter that has a table giving the configuration file sizes. Have a look at this one (http://www.altera.com/literature/hb/cyclone-iv/cyiv-51008.pdf), page 8-4 and 8-5. The uncompressed configuration size for an EP4CGX110 is 39,425,016 bits so you already need serious compression to even fit one FPGA image in an EPCS16.
