21602 Discussions
EPM CPLD's Internal Osc Frequency
Hi!
I'm working with a EPM570 and need a clock source.
I created it with the block ALTUFM_OSC, set the frequency to 5.5 MHz and checked it worked by simulating the circuit.
As stated in the help file of ALTUFM_OSC, the frequency of 5.5 MHz I've selected it's only "for simulation purpouses and has no impact on the on-chip oscillator frequency".
My question is, what will be the real frequency of the oscillator when I upload the source code to the CPLD? Is it uncertain and will be between 3.3 and 5.5 MHz?
If it's really uncertain and I need a deterministic frequency for the global clock, how can I interface a crystal into the CPLDs pins?
It may have been asked before, but I had no luck finding the answers.
Thanks in advance for your help.
The frequency wont be reliable and will vary with temperature. According to the documentation it will only be in the range you specify though.
p43 says the real frequency can be between 3.33MHz and 5.56MHz
http://www.altera.com/literature/ug/ug_alt_ufm.pdf
Rather than trying to build an oscillator circuit using a crystal, just use an oscillator.
http://www.ecliptek.com/
http://www.ecliptek.com/oscillators/ec26/
Route the output of the oscillator to the clock pin of the CPLD.
Cheers,
Dave
Thanks a lot for your help Dave and Tricky!
Didn't know there are crystal oscillators with TTL/CMOS output.
Bye!
