21602 Discussions
EPM1270 i/o problem
I read a CS5532 when EPM1270 found a problem. I give an order of 5532, when the internal logic of concurrent write a command to the SCLK pin on the pin but occasionally did not wave. I count the internal logic of the output and found that the data actually sent me, just do not know why the pin did not respond. So I divided by the system clock connected to the SCLK pin when the pin output is also normal, no-no wave.
Sounds like a logic design error, e.g. timing related. Without knowing design details and exact observations, we can only guess about it.
module _ad_spi(
input wire clk,//
input wire rst_n,
input wire _init_start,
input wire output_enable,
input wire output_flag,
input wire [7:0] _AD_indata,
output reg [23:0] _AD_outdata,
output reg _Get_Data_Flag_out,
output reg _AD_sclk,//SPI port
output reg _AD_sdo,
input wire _AD_sdi
reg [2:0] state; // statemachine state
reg [5:0] transmit_count; //transmit count
reg [23:0]_AD_data; //temp 24bits data
reg _get_data_over; //get data over flag
reg [7:0] treg; //transmit reg
always @(*)//out put data
begin
if(!rst_n) _AD_outdata <=0;
else if(output_enable&&_get_data_over == 1) _AD_outdata <= _AD_data;
end
always @(posedge clk or negedge rst_n)
if (~rst_n)
begin
state <= 3'b000; // idle
transmit_count <= 6'b000000;
treg <=# 1 8'h00;
_AD_sclk <= 1'b0;
_AD_sdo <= 0;
end
else
begin
_Get_Data_Flag_out <= 0;
case (state) //synopsys full_case parallel_case
3'b000: // idle state
begin
transmit_count <= 6'b000000; // set transfer counter
treg <= 8'h00; // load transfer register
_AD_sclk <= 1'b0; // set sck
_AD_sdo <= 1'b0;
if(output_flag )//&_init_start)
begin
treg <= _AD_indata;// load transfer register
transmit_count <= 6'h7; // set transfer counter
state <= 3'b001; // transfer data state
_Get_Data_Flag_out <= 1;
_AD_sdo <= _AD_indata[7];
end
else if (~_AD_sdi)// & ~_init_start)
begin
transmit_count <= 6'h28; // set transfer counter
_get_data_over <= 0;
end
end
3'b001: // clock-phase2, next data
begin
_AD_sclk <= ~_AD_sclk;
if(transmit_count == 6'h7)
state <= 3'b011; // send data state
else if(transmit_count == 6'h28)
state <= 3'b101; // recive data state
else
state <= 3'b000; // idle state
end
3'b011: //send data state
begin
if(~_AD_sclk)
begin
_AD_sdo <= treg;
transmit_count <= transmit_count -6'h1;
end
if (~|transmit_count)
begin
state <= 3'b000;
_AD_sclk <= 0;
_AD_sdo <= 0;
end
else
begin
state <= 3'b011;
end
end
3'b101: //recive data state
begin
if(_AD_sclk)
begin
if(transmit_count >7 && transmit_count < 32)
_AD_data <= _AD_sdi;
end
_AD_sdo <= 0;
if (transmit_count == 0 || transmit_count >40)
begin
state <= 3'b000;
_AD_sclk <= 0;
if(transmit_count >40) _get_data_over <= 0;
else _get_data_over <= 1;
end
else
begin
state <= 3'b101;
_AD_sclk<= ~_AD_sclk;
end
end
default: state <= 3'b000;
endcase
end
endmodule
This is my program, you help me see, what is the problem
I count the SCLK output is normal, and SCLK, and DOUT is simultaneously, or both did not
