Programmable Devices
Comunicados
21615 Discussões
EPM240T100C5 not work reading data from RAM
Colaborador honorário II
1.180 Visualizações
Hi can someone help me with reading data from RAM, please
my code is very easy look:
module dds_generator(clk,signal_output); input wire clk; output wire signal_output; reg phase_acumulator; initial phase_acumulator = 32'd0; //assign signal_output = phase_acumulator; ram1_port sin( .address(phase_acumulator), .data(), .outclock(clk), .we(1'b0), .q(signal_output)); always@( posedge clk ) begin phase_acumulator <= phase_acumulator + 32'd85899; // end endmodule
compile project without errors but not use any CPLD resources :confused:
http://www.alteraforum.com/forum/attachment.php?attachmentid=12567&stc=1
RTL viewer : I thinks this is good
http://www.alteraforum.com/forum/attachment.php?attachmentid=12568&stc=1
I dont know why :(
thaks for help me
1 Responder
455 Visualizações
Is your signal_output signal connected to pins outside of the FPGA? If not the whole module will be optimized away by the synthesizer.
How do you load data in the RAM? I don't know if the synthesizer is smart enough, but it's possible that if it detects that you can never write anything in the module and that it's just initialized with zeros, that it will "optimize" your code by just outputting zeroes.
Responder
