21615 Discussions
Why is the use of different PLL feedback modes in Altera devices?
The documentation states that the Altera PLLs have 6 different clock feedback modes. These are:
1. Direct mode
2. Normal mode
3. Source-Synchronous mode
4. External Feedback mode
5. Zero-Delay Buffer mode
6. LVDS mode
Why are there so many clock feedback modes and how do I know which one I need?
--- Quote Start ---
1. Direct mode
2. Normal mode
6. LVDS mode
--- Quote End ---
They are offered to tackle timing problems in case you have io violations.
Direct : only de-jitters clock, does not compensate for delay.
normal, de-jitters and reduces clock delay from pin to register and compensates for clock delay from pin
source synchronous, keeps data/clk phase same between pins and registers
external: relevant if so
zero delay: relevant to an output clock from pll, maintains same phase of output clock as that of input clock.
lvds: relevant to serdes.
if I am connecting a audio DAC that needs MCLK (master clock) and takes I2S signals SCLK, Data and LRCK (same frequency as audio sample rate, used to select left/right channels), and I intend to generate MCLK and other clock signals from a PLL inside the FPGA, which of these shall I need to use?
