Programmable Devices
21602 Discussions
EPM7256EGI192 BSDL
fred1973
Where I can find the BSDL for an EPM7256EGI192 (PGA 192).
Thank you for your answer.
Ash_R_Intel
Please search for the required on the following page:
https://www.intel.com/content/www/us/en/search.html?ws=text#q=Max%207000%20bsdl&sort=relevancy
fred1973
Sorry, but no bsdl was found on the page for the EPM7256EGI192 (PGA 192) (I had already checked).
Semi-E
Have you looked at https://bsdl.info/download.htm?sid=c74bda6545c4412d88ca59b002289d77
hopefully it’s felpful.
Ash_R_Intel
Yes, you are right. The BSDL for EPM7256EG 192-pin PGA is missing. I searched in internal database as well, and it's missing there too.
Unfortunately, there is no support for this now, as it was discontinued long time back.
I am curious to know why do you need support on such an old device? If possible, to migrate to a newer CPLD/FPGA, it would be the best.
fred1973
I just need to do some Jtag test on this component.
On rereading the datasheet, I suspect that version E does not have the Jtag function implemented. Can you confirm this supposition?
FvM
MAX7000 datasheet is clear about JTAG BST function being only present in S types, e.g. EPM7256S as well as low voltage A and B types.
Hence no BSDL file available.
Frank
