21615 Discussions
ESD test on cyclone 2
Hi.
We have board designed around Cyclone 2 in 240 pin package(QFP). On this board beside fpga is located memory(DDR RAM) and lvds converters.
In the order to done esd test I implemented simple test design which controll LEDs in VHDL and NIOS 2 processor. The processor uses internal memory na lvds links are not used.
So. I perform esd tests( 4KV - 10KV) on our board. It shows that our HDL design + soft processor (NIOS 2) are frequently reloaded duing esd test (also at 4KV). The most frequently reloading is performed when esd test is done around digital power supply (3.3V, 1,2V).
I suspect that motion is distributed trough power supply to FPGA, although I have implemented power supply according Altera recommendation.
I would like if anybody has experiences with esd test of cyclone 2 in this package?
Thank you in advance,
Amir Hasanovic
Did you try to add some capacitors, ESD-diods and inductances to/aounrd the pin to find out if there is some influence ?
Thanx for answer,
I added few capacitors to filter 3.3V and 1.2V voltages.
It results in better operation.
Now, I have to include external memory and m-lvds converters. These could make additional problems during esd test, because of ground debounce...Wrong access to external memory can cause error in nios 2 processor.
ESD diodes are added on the rs232 interface.
Pita
From here, it is hard to suggest solutions.
To me it should be possible to "record" the bahavior of the power lines and signal lines with a oscilloscope when ESD tests are taking place. You might be able then to decice, if it is just an error caused by instable power voltage, as I assume. In case of peeks on the lines, additional suppressor diodes in beneath of the chip might help.
Pay attesion to the power filters including the power supply for oscillocator.
