Programmable Devices
21615 Discussions
Emulated LVDS
hello everybody :)
i'm using Stratix III. what is the diffrence between the dedicated LVDS IO to the emulated LVDS IO?
thanks;)
Emulated LVDS is actually voltage mode: Signal is sent to the positive pin, same signal go through one not gate inside FPGA and be sent to the negative pin.
Dedicated LVDS IO buffer is current mode.
As a practical difference, the achievable data rate is considerably lower.
can I reach 500Mhz with the emulated output LVDS channles?
In the Stratix III Device Handbook, you find table 1–24. high speed i/o specifications
It tells, maximum LVDS data rate is 550 MHz with LVDS_E_3R IO-standard and C2 speed grade.
And which maximum data rate can i achieve in cyclone III EP3C16Q240C8N ? In datasheet i found only for Cyclone III LS mini LVDS max.speed 311Mbps. It is same in Cyclone III ?
Thank you.
Thanks for opening this thread, it answered my question.
However, I have a quick follow-up question:
It says about emulated LVDS in the pin connection guidelines:
"External resistor network is needed for emulated LVDS output buffers."
What is meant by that?
Adam
You want to read Cyclone III Device Handbook, Chapter 7. high-speed differential interfaces in the cyclone iii device family
See e.g. Figure 7–3. LVDS Interface with External Resistor Network on the Top and Bottom I/O Banks
For other devices than Cyclone III, do a manual text search for "emulated LVDS".
