Programmable Devices
Comunicados
21615 Discussões
Emulated LVDS
Colaborador honorário II
3.648 Visualizações
hello everybody :)
i'm using Stratix III. what is the diffrence between the dedicated LVDS IO to the emulated LVDS IO?
thanks;)
7 Respostas
2.514 Visualizações
Emulated LVDS is actually voltage mode: Signal is sent to the positive pin, same signal go through one not gate inside FPGA and be sent to the negative pin.
Dedicated LVDS IO buffer is current mode.
2.514 Visualizações
As a practical difference, the achievable data rate is considerably lower.
2.514 Visualizações
can I reach 500Mhz with the emulated output LVDS channles?
2.514 Visualizações
In the Stratix III Device Handbook, you find table 1–24. high speed i/o specifications
It tells, maximum LVDS data rate is 550 MHz with LVDS_E_3R IO-standard and C2 speed grade.
2.514 Visualizações
And which maximum data rate can i achieve in cyclone III EP3C16Q240C8N ? In datasheet i found only for Cyclone III LS mini LVDS max.speed 311Mbps. It is same in Cyclone III ?
Thank you.
2.514 Visualizações
Thanks for opening this thread, it answered my question.
However, I have a quick follow-up question:
It says about emulated LVDS in the pin connection guidelines:
"External resistor network is needed for emulated LVDS output buffers."
What is meant by that?
Adam
2.514 Visualizações
You want to read Cyclone III Device Handbook, Chapter 7. high-speed differential interfaces in the cyclone iii device family
See e.g. Figure 7–3. LVDS Interface with External Resistor Network on the Top and Bottom I/O Banks
For other devices than Cyclone III, do a manual text search for "emulated LVDS".
Responder
