Programmable Devices
21611 Discussions
Error (10198): Verilog HDL error at altera_merlin_width_adapter.sv
I created a Qsys component in VHDL where the rest of my design is in verilog. I created the Qsys system and I try to do a synthesis and get the following cryptic error :
Error (10198): Verilog HDL error at altera_merlin_width_adapter.sv(433): part-select direction is opposite from prefix index direction
Error (10784): HDL error at altera_merlin_width_adapter.sv(432): see declaration for object "int_ratio_minus_1"
Error (12152): Can't elaborate user hierarchy "embedded_system:u0|embedded_system_mm_interconnect_0:mm_interconnect_0|altera_merlin_width_adapter:width_adapter_001"
And those lines (432 and 433) are the following:
wire [31:0] int_ratio_minus_1 = (cmd_burst_size/OUT_NUMSYMBOLS) - 1;
wire [clogb2(RATIO)-1:0] sized_ratio_minus_1 = int_ratio_minus_1[clogb2(RATIO)-1:0];
Any clues what is wrong?
Salman
Never mind...i was using a 24-bit write and readdata bus...once I fixed it to 32, errors gone.
