21585 Discussions
Error (209053): Unexpected error in JTAG server -- error code 38
RaulEstrada
I'm dealing with an issue trying to program the EPM570F100 with a USB blaster and with Quartus Prime Programmer Version 17.1.0 but even the JTAG chain is executed successfully:
Chain Continuity Checker
Chain Continuity during IR is not stuck at zero or one
Chain Length -- Load IR of all ones then count DR length
Number of Devices is 2
IR Length Calculator
Instruction Register Length is 16
IDCODE Reader
TDO -> TDI | Rev  Device              Mfgr          1 | ID (HEX) |
Device #1  | 0000 0010 0000 1010 0010 0000 1101 110 1 | 020A20DD |
Device #2  | 0010 0011 0111 0101 0001 0000 1001 001 1 | 23751093 |
Device Identifier -- Search for device name from list of device IDCODE values
TDO -> TDI |      Device              Mfgr            |
Device #1  |      EPM570              Altera          |
Device #2  |      Unknown IDCODE                      |
Exit code = 0... Success
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
the following errors appears:
Info: Processing started: Thu Jul 20 16:10:51 2023
Info: Command: quartus_pgm -c 1 file1.cdf
Info (213045): Using programming cable "USB-Blaster [USB-0]"
Info (213011): Using programming file file2.pof with checksum 0x002C5D97 for device EPM570F100@2
Info (209060): Started Programmer operation at Thu Jul 20 16:10:51 2023
Error (209053): Unexpected error in JTAG server -- error code 44
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Thu Jul 20 16:10:52 2023
Error: Quartus Prime Programmer was unsuccessful. 3 errors, 1 warning
Any advise? Already tried different USB blaster and device
WZ2
Hi there,
To solve this issue, there are some points I need to make clear:
  1. Do you use the Altera's USB-Blaster II?
  2. What system u used? Windows or Linux?
WZ
RaulEstrada
Hi WZ2,
I'm using old version USB-Blaster (not version II) and  using windows 10.
Note the driver for this is ok and working correctly according device manager.
Raul
WZ2
I see you do some debug on this issue. The reason of device, usb line and the JTAG chain's transfer work well. There are some advice I can see:
  1. Make sure the device work well and there is no voltage drop during the configuration.
  2. Try to use other easy sof to do the program, and use programmer to do the test.
  3. Although you already change the device, I still suggest to kill the process of jtaged and try again.
WZ
WZ2
Hi there,
Is it solved~
WZ2
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
RaulEstrada
Not  resolved yet. I was on vacations and even I have tried suggestions provided before no changes. I will verify this week other suggestions provided by my technical coworkers and let it know if any progress, keep posted.
