21589 Discussions
Error - AXI Master BFM: mgc_axi_slave.sv not supported for Quantum synthesis
I am currently trying to instantiate HPS as prescribed in the document: av_5v4_08.pdf from Altera.
I attached AXI Master and Slave BFMs to the f2h, h2f and lw interfaces.
And when I try to generate simulation, testbench and synthesis in qsys, the error as in the title of this post occurs.
It points at mgc_axi_slave.sv which is not supported for Quantum synthesis, only for Verilog simulation or VHDL simulation.
I find this problematic since I also found the file mgc_axi_slave.sv in the GHRD example but the latter succeeds generating simulation, testbench and synthesis.
Any help, comment, suggestion pertaining to the proper use of the AXI BFMs will be much appreciated.
Martin
