21615 Discussions
Error:No Nios II target connection paths were located.
Hi! Everytime i am trying to run my NIOS application on the Cyclone III, EP3C25F324C8NES I am getting this Error.
No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded.
but not getting the reason why m getting so.
plz help.
Did you configure the board with a sof file? Which one?
Thanx for replying me.
I m using the following sof file,
CIII_NiosII_Small.sof
the example file i got with CD.
But i have installed Quartus 9.1 but the example is of Quartus 7.1
if this can be a problem. do i need to install Quartus 7.1 ?
regards
Are you using an Altera development kit? Was that sof file distributed with the kit?
IIRC the sof files given with the Cyclone III starter kit have different names.
yes i m using its development kit, Cyclone III EP3C25F324 FPGA one.
On the files that Altera distribute for the Cyclone III starter kit, there is one design example with a Nios CPU, and the sof file is called cycloneIII_3c25_start_niosII_standard.sof
Are you sure that the sof file you have is designed for the kit you have?
Did you ever find a solution to your problem? I am having the same problem on the BeMicro board.
I started the project in Altera 9.1 both Quartus and eclipse and it worked fine I was able to find the device, program, and debug.
I then updated Quartus to SP1 and started back into the software side of things I was able to use Quartus to download to the BeMicro but eclipse would not find the target. I then upgraded both Quartus and eclipse to sp2 still no dice. I've even reloaded the drivers for the BeMicro. any ideas?
thanks
Steve
--- Quote Start ---
--- Quote End ---
In the bemicro download there is a folder called "programmer" that includes the file "setup.exe". You have probably already run it and placed the DLL in the "C:\altera" folder as the instructions state, but it needs to be in "C:\altera\91sp2\quartus\bin" for SP2. Probably similar folder for SP1.
