21615 Discussions
Error due to always enabled I/O buffer
Hi all,
I had generated a SOPC system using sdram controller, jtag, 2 pio and nios. When I compile the design, it shows error as shown below:
Error: The node "try:NiosII|sdram_0:the_sdram_0|za_data[11]" has multiple drivers due to the always-enabled I/O buffer "try:NiosII|zs_dq_to_and_from_the_sdram_0[11]"
try is the SOPC system name. For the sdram, I had also connected pll for clock skew. The error is not for za_data[11] only but also for [1] to [15]. Please help. I thought generated SOPC would not have any problem in compilation but guess I am wrong.
I had found the source of the errors and fix it. It is because the node is not connected properly.Thank you.
Could you please tell me the way to solve this kind of problem in detail.thank you!
I'm having exactly the same issue.....
Can somebody suggest some solution???? This error relates to the files generated by SOPC.
I had the exact same problem. It turned out that the bus width in my top level deisgn did not match the bus width in SOPC builder.
In SOPC Builder the bus width was 5, and in my top level file it was 3 ( [0:2] )
