Programmable Devices
21611 Discussions
Error in simulation due to unknown generated files in Modelsim
Hi all,
I have made a Modelsim project and added 3 files to the project. After compilation, I have simulated pkt_enco_tb file as it is my testbench file. but I am getting errors as shown in attached image.
Also, I have seen that after compilation, unknown files were generated like 'pkt_enco_tb_sv_unit' and 'pkt_encoder_sv_unit', I have attached an image for this. So I want to know that what is the significance of these files?:confused:
and how to solve this error?.:confused:
thank you.
The images are not clear, attach the transcript.
Are you trying to simulate an individual IP / Own soc design?
Can you share the design?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote Start ---
Anand Raj Shankar
--- Quote End ---
Hi, now you can see the images I have uploaded high-resolution images.
And yes, I am trying to simulate my own design.
Can you share the files?
To debug
1. Can you try to simulate individual .v/.vhd file first?
And find the file which causes the problem. Also, try to check the logic of it and its integration to the top file.
Anand Raj Shankar
Somehow I got the solution by changing the order of files in the compilation. And keep the package files in the same folder where my testbench is. Below is my testbench code.
I have come across another issue. I am using 2 package files, in the first package file, I have defined multiple byte structures. And using the first package I have defined structures of the group of bytes. So my case is, from testbench I have to write individual byte as per the first package and I have to read group of byte from second package. I am able to write in frist package but I did not get it from second package. So I want to know that is it possible ? if yes then How? and If no then what I can do for that?
--- Quote Start ---
To debug
Anand Raj Shankar
--- Quote End ---
I have solved this issue by the refreshing library in Modelsim before simulation.
