Programmable Devices
21602 Discussions
Error: rs232_0: The input clock frequency must be known at generation time.
FPGAOLOG
I try to instantiate an RS232 UART Intel FPGA IP. and it gives the following error during generation:
I tried the workarounds available in Intel resources, Both Intel IP catalog or Platform designer does not work. Platform designer has clock source instantiated and clock frequency set properly.
21.2
RichardTanSY_Altera
Have you try the solutions below and see if it helps to solve your error?
https://stackoverflow.com/questions/51346684/quartus-18-ip-error
MTw
Thanks a lot. This solution worked for me!
RichardTanSY_Altera
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
FPGAOLOG
I have tried the solution and mentioned it did not work in the original message which was replied with the solution that did not work.
