Programmable Devices
21611 Discussions
Error while generating and compiling the Preloader.
I had done as per the points given in the rocketboard link http://rocketboards.org/foswiki/view/documentation/gsrd131preloader .
But while trying to build the preloader image using the "make" command. It is showing an error " #error If ECC is enabled, Scrubbing should also be enabled."
Kindly provide suggestion to overcome this error.
The above error is soved after enabling the RAM scrubbing in BSP editor.
The preloader is programed to the controller using quatrus_hps.exe software. and it is working fine after power-on reset.
But now i had a doubt..
How to add the user code (LED blinking code ) after the preloader.??? i.e after execution of preloader, the user-code should be run...???
Please suggest me in solving the problem.
Hello, you can refer to AN709. To load usercode/application right after preloader loaded, in the bsp-editor, change the spl.boot.SDMMC_NEXT_BOOT_IMAGE=0x40000. This is where you will put the usercode/application.
