I had done as per the points given in the rocketboard link http://rocketboards.org/foswiki/view/documentation/gsrd131preloader . But while trying to build the preloader image using the "make" command. It is showing an error " #error If ECC is enabled, Scrubbing should also be enabled." Kindly provide suggestion to overcome this error.- Tags:
- Error
The above error is soved after enabling the RAM scrubbing in BSP editor. The preloader is programed to the controller using quatrus_hps.exe software. and it is working fine after power-on reset. But now i had a doubt.. How to add the user code (LED blinking code ) after the preloader.??? i.e after execution of preloader, the user-code should be run...??? Please suggest me in solving the problem.- Mark as New
Hello, you can refer to AN709. To load usercode/application right after preloader loaded, in the bsp-editor, change the spl.boot.SDMMC_NEXT_BOOT_IMAGE=0x40000. This is where you will put the usercode/application.
