21605 Discussions
Error with Virtual JTAG
Hi everyone,
I created a Virtual JTAG in MegaWizard Plug-In Manager and its instant below:
module counter (clock, my_counter); input clock; output my_counter; reg my_counter; always @ (posedge clock) if (load && e1dr) // decode logic: used to load the counter my_counter my_counter <= tmp_reg; else my_counter <= my_counter + 1; // Signals and registers declared for VJI instance wire tck, tdi; reg tdo; wire cdr, e1dr, e2dr, pdr, sdr, udr, uir, cir; wire ir_in; // Instantiation of VJI Virtual_JTAG Virtual_JTAG_instant( .tdo (tdo), .tck (tck), .tdi (tdi), .tms(), .ir_in(ir_in), .ir_out(), .virtual_state_cdr (cdr), .virtual_state_e1dr(e1dr), .virtual_state_e2dr(e2dr), .virtual_state_pdr (pdr), .virtual_state_sdr (sdr), .virtual_state_udr (udr), .virtual_state_uir (uir), .virtual_state_cir (cir) ); // Declaration of data register reg tmp_reg; // Deocde Logic Block // Making some decode logic from ir_in output port of VJI wire load = ir_in && (~ir_in); // Bypass used to maintain the scan chain continuity for // tdi and tdo ports bypass_reg <= tdi; // Error here // Data Register Block always @ (posedge tck) if ( load && sdr ) tmp_reg <= {tdi, tmp_reg}; // tdo Logic Block always @ (tmp_reg or bypass_reg) if(load) tdo <= tmp_reg; else tdo <= bypass_reg; endmodule
and I got this error:
Error (10170): Verilog HDL syntax error at Virtual_JTAG_instant.v(46) near text "<="; expecting ".", or "("
Can anyone help me solve this issue? :D
You're using VHDL syntax. Use Verilog syntax:
assign bypass_reg = tdi;
Cheers,
Dave
