Programmable Devices
21609 讨论
External Input clock frequency of 10M08DCU324I7G
Navaneethakrishnan
初学者
1,726 次查看
We are using 10M08DCU324I7G FPGA in our design. Kindly let me know the what is minimum and maximum frequency of external oscillator input frequency
0 项奖励
1 解答
AqidAyman_Intel
1,657 次查看
Yes, you are correct.
Aqid Ayman
在原帖中查看解决方案
0 项奖励
8 回复数
Farabi
员工
1,706 次查看
What is the part number of your external oscillator? you can check from that particular external oscillator's datasheet about the supported input frequency.
regards,
Farabi
0 项奖励
Navaneethakrishnan
初学者
1,700 次查看
Hi
I need 10M08DCU324I7G FPGA's minimum and maximum external support frequency.
0 项奖励
AqidAyman_Intel
1,685 次查看
You can refer to this link : PLL Specifications (intel.com)
Aqid Ayman
0 项奖励
Navaneethakrishnan
初学者
1,678 次查看
In that link, PLL Input clock frequency mentioned as 5MHz to 472.5MHz. So we need to select the external crystal oscillator to be selected in that range, since we cannot drive PLL with internal oscillator. Whether my understanding is correct or not?
I have attached the snapshot from MAX10 handbook for reference.
0 项奖励
AqidAyman_Intel
1,658 次查看
Aqid Ayman
0 项奖励
Navaneethakrishnan
初学者
1,653 次查看
Thanks for your reply
0 项奖励
AqidAyman_Intel
1,646 次查看
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
0 项奖励
Navaneethakrishnan
初学者
1,638 次查看
One more clarification, If we are not use PLL in our application, Can we use 4MHz external crystal? Whether 10M08DCU324I7G will support for 4MHz?
0 项奖励
回复
