21602 Discussions
External Input clock frequency of 10M08DCU324I7G
Navaneethakrishnan
We are using 10M08DCU324I7G FPGA in our design. Kindly let me know the what is minimum and maximum frequency of external oscillator input frequency
AqidAyman_Intel
Yes, you are correct.
Aqid Ayman
Farabi
What is the part number of your external oscillator? you can check from that particular external oscillator's datasheet about the supported input frequency.
regards,
Farabi
Navaneethakrishnan
Hi
I need 10M08DCU324I7G FPGA's minimum and maximum external support frequency.
AqidAyman_Intel
You can refer to this link : PLL Specifications (intel.com)
Aqid Ayman
Navaneethakrishnan
In that link, PLL Input clock frequency mentioned as 5MHz to 472.5MHz. So we need to select the external crystal oscillator to be selected in that range, since we cannot drive PLL with internal oscillator. Whether my understanding is correct or not?
I have attached the snapshot from MAX10 handbook for reference.
AqidAyman_Intel
Aqid Ayman
Navaneethakrishnan
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Navaneethakrishnan
One more clarification, If we are not use PLL in our application, Can we use 4MHz external crystal? Whether 10M08DCU324I7G will support for 4MHz?
