21615 Discussions
Extremelly confused in Cyclone V Transceivers reconfiguration
Hello dear friends.
I have a Cyclone V 5CSXFC6D6F31C8 chip. On PCB board, all 9 transceivers are connected to periphery and 1 reference clock (REFCLK1L) are connected to reference clock source (other reference clocks are grounded).
I want to build 9-channel transceiver that have reconfigurable speed (700/2800Mbps) on each channel independently on other channels.
So i can build project with single reconfigurable channel, but i totally cant build 9-channels reconfigurable project.
I read Transceiver User Guide, AN676 and tons of other information but can't build all channels are reconfigurable.
I try these solutions:
1. 9-channel transceiver with bonded/non-bonded internal TXPLL's - cant compile.
2. 9-channel transceiver with bonded/non-bonded external TXPLL's (two Transceiver PLL) - cant compile.
3. 9-channel transceiver with bonded/non-bonded external TXPLL's (two Fractional PLL) - cant compile.
4. 9-channel transceiver with bonded/non-bonded external TXPLL's (Mixed Transceiver and Fractional PLL) - cant compile.
At all variants Quartus compilation fails with errors.
Please help me because i'm critically confused with it...
Lot of thanks to all.
p.s.: i attach my test project that fails.
https://alteraforum.com/forum/attachment.php?attachmentid=13904&stc=1
So, i continue experiments: any configurations with channels count 2 and more will fails at fitter stage.
I try also external FPLL with 2-clock output, but it fails too because transceiver core need to be clocked from PHOUT output that drives only one clock.
Can anybody say me what i do wrong?
Hmmm... Nobody have same problems?
So i return to this problem after some time.
Now i'm stay off in this point:
The project consist of these modules:
- Separate FPLL with it own PLL Reconfigurator IP.
- Transceiver in external PLL mode (i use 2 TX PLL's - TXPLL0=622.08 and TXPLL1=2488.32, bonding xN used).
- Base speed of transceiver is 622.08 (and 322.04 for FPLL respectively).
- Transceiver reconfiguration IP (number of channels same as number of channels in transceiver, MIF reconfiguration enabled).
What results i have:
For channels count from 1 to 6 compilation are successful.
For channels count from 7 to 8 compilation fails with errors:
Info (170193): Fitter routing operations beginning Error (170084): Can't route signal "xcvr:inst3|altera_xcvr_native_av:xcvr_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.int_wire_clk" to atom "xcvr:inst3|altera_xcvr_native_av:xcvr_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_cgb" Error (170084): Can't route signal "xcvr:inst3|altera_xcvr_native_av:xcvr_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.int_wire_clk" to atom "xcvr:inst3|altera_xcvr_native_av:xcvr_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_cgb" Info (170194): Fitter routing operations ending: elapsed time is 00:00:01
Can anybody help me with it?
