Hi all,
I'm trying to use Modcoupler from PSIM for mixed simulation (VHDL+analog) I have an error in ModelSIM shell:# ** Error: (vsim-FLI-3155) The FLI is not enabled in this version of ModelSim. I use ModelSim Altera Starter Edition 6.5e. Do I need to use ModelSIM SE/PE. Thanks a lot. Pierre.Link Copied
The starter edition is severly limited. so yes, you will probably need to purchase the SE or PE edition.
Yes, after asking to PSIM support, I confirm that Modcoupler is not compatible with ModelSim Starter Edition. What a pitty.
A+ Pierre
