Is its possible to flash an EPC1 device with .pof file using quartus programmer?
HI intfpga2,
What FvM has stated is indeed true. From the EPC1 Datasheet:
"Programming support with Altera’s Master Programming Unit (MPU) and programming hardware from Data I/O, BP Microsystems, and other manufacturers"
Else, easier with JTAG programmable EPC2.
Fakhrul
you need old "Altera Master Programming Unit (MPU)" or more likely a third party parallel programmer supporting EPC1.
Simpler to switch to JTAG programmable EPC2 etc.
you mean Max-plus 11 tool, or the third party tools like Elnec?
As said Altera MPU or third party. I guess you don't have access to MPU, so third party is your option. Several Elnec devices are supporting EPC1 according to web site.
HI intfpga2,
Fakhrul
