Programmable Devices
21615 Discussions
FMC vs interlaken
hi,
what is the difference betwwen interlaken and FMC?
thx
You can't really compare FMC and Interlaken. There isn't anything the same about them - except, perhaps, they're both aimed at supporting higher bit rates.
FMC is Altera's name for a type of physical connector that they (and others) use. Interlaken is a protocol that you might run over a physical link that may (or may not) run over an FMC connector.
Have a read of:
http://www.altera.com/technology/high_speed/protocols/interlaken/pro-interlaken.html (http://www.altera.com/technology/high_speed/protocols/interlaken/pro-interlaken.html
to give you an overview of Interlaken.
Altera's FMC is a custom connector made by Samtec, part number: ASP-134486-01
http://www.samtec.com/documents/webfiles/cpdf/asp-134486-01-mkt.pdf (http://www.samtec.com/documents/webfiles/cpdf/asp-134486-01-mkt.pdf
This connector is used on a number of Altera's development boards.
ok thx..
so if i truelly understood the concept, we can have an fpga board hwo has fmc connector and it implement interlaken protocol
The following Samtec document discussed the high speed characteristics of a cable assembly that mates with the same connector.
http://www.samtec.com/documents/webfiles/testrpt/hsc-report_hdr-153514-xx_vita57-hpc_web.pdf (http://www.samtec.com/documents/webfiles/testrpt/hsc-report_hdr-153514-xx_vita57-hpc_web.pdf
It discusses the cable's speed rating and suggests 15Gbps should be possible.
So, yes. You should be able to implement a physical layer link, operating an Interlaken protocol, over the FMC connector.
thank you a lot
