21607 Discussions
FPADD FPMULT for NIOS + Cyclone
Not completely tested and in AHDL for compactness (will make VHDL and Verilog versions later) but runs at around 100Mhz in C6 grade cyclone 3 stage latency
32 bit version adder is approx 470LE, mult is approx 750LE
Fully parameterisable - does double precision also (10bexp, 52bit mant + sign) - NOT IEEE as I designed it to be fast!
This should be all the parts needed (attached)....
Steve.
Ok, Ok - here a front end so it handles IEEE - sheesh.
Steve...
and VV
Steve,
Looks very interesting.
Have you tested it as CI for NiosII ? If yes, could you share a reference design + peace of code showing the performance of your solution ?
Maga
--- Quote Start ---
originally posted by maga@Aug 12 2004, 02:58 AM
steve,
looks very interesting.
have you tested it as ci for niosii ? if yes, could you share a reference design + peace of code showing the performance of your solution ?
thanks,
maga
--- Quote End ---
Working on that right now - will post the full project when done - just handed out the FPcore as a general IP for some to play with...
Steve ...
