21602 Discussions
FPGA Stratix II Pin assignment and control panel
Hi guys,
I am using FPGA Stratix II board EP2S60F1020C3ES. I can't find the pin assignment for it also can not find the control panel .exe file to test the board
any help will be appreciated :)
You've provided an FPGA *part number*, not a board type. If you can figure out what board you have, then some one might be able to help.
For example, is this the Stratix II DSP Development Kit?
Cheers,
Dave
Yes, it is Stratix II DSP Development Kit
Mourad
This is the link for the Board I have
http://www.altera.com/products/devkits/altera/kit-dsp-2s60.html
Mourad
Since I can not provide link for the board. It can be seen on Altera website in the following sequence
Home > Products > Development Kits/Cables > DSP Development Kit, Stratix II Edition
Mourad
Hi Mourad,
--- Quote Start ---
--- Quote End ---
Ok, here's a design for that kit.
Keep in mind two things;
1. Stratix II devices require a Quartus II subscription edition.
2. The "ES" version of this board sucks, because the M-RAM does not work on the ES samples. (Unfortunately I have an ES version)
I see the main Altera site doesn't have much info regarding this board any more. Let me know if you want the schematic or anything else, as I probably have the CD-ROM that shipped with the kit.
Cheers,
Dave
PS. I just re-read your original post and see that you have the ES device - bummer. Make sure you edit synth.tcl to change to use the ES part number.
Hi Dave,
Thanks for your help man, Really appreciated :)
Cheers,
Mourad
Hi Dave,
I very new in using tcl console.
I am trying to run the synthesis script but every time I receive an error
These are the steps that I carried out:
1- I have put the four files (s2_dsp,hex_display,synth,pinout) together in one folder and called it s2_dsp
2- Created a Quartus project with name "s2_dsp"
3- In the tcl console I wrote tcl> source synth.tcl
Am I missing any steps ?
This is the ERROR that I receive each time:
source synth.tcl
Synthesizing the S2-DSP 'basic' design
- Creating the Quartus work directory
- Creating the VHDL files list
Error:ERROR: Can't open project: s2_dsp
Error: while executing
Error:"project_new -overwrite "s2_dsp""
Error: (file "synth.tcl" line 64)
Error: invoked from within
Error:"_source synth.tcl"
Error: ("uplevel" body line 1)
Error:"uplevel 1 $cmd "
Error: (procedure "source" line 5)
Error:"source synth.tcl"
Mourad
--- Quote Start ---
3- In the tcl console I wrote tcl> source scripts/synth.tcl
--- Quote End ---
The zip file has a readme.txt that explains what you were supposed to do.
You did not need to create a Quartus project. The script does everything. Here's what you were supposed to do:
Stratix II DSP Development Kit 'basic' Design --------------------------------------------- 4/17/2014 D. W. Hawkins (dwh@ovro.caltech.edu) A user on the Altera Forum asked about the pinout for this board. I created this stripped down 'basic' design from my code repo. The design was synthesis tested using Quartus 12.1sp1 subscription edition. There is no SDC file for this project, so Quartus generates a warning. To synthesize the design; 1. Unzip this file eg., c:/temp/s2_dsp_basic 2. Start Quartus and select the Tcl console (make it visible with View->Utility Windows->Tcl Console) 3. Run the synthesis script tcl> cd c:/temp/s2_dsp_basic tcl> source scripts/synth.tcl Synthesizing the S2-DSP 'basic' design -------------------------------------- - Creating the Quartus work directory - Creating the VHDL files list - Applying constraints - Processing the design - Processing completed NOTE: The earlier version of this kit shipped with "ES" devices (engineering samples). The synth.tcl script assumes you have a production device (non-ES) .Edit that script if you have an ES board. Enjoy! Cheers, Dave
Cheers,
Dave
Hi Dave,
Sorry, it might be a silly question from me but how can I access the synthesis file without showing Quartus software the right directory.
because if I just follow the steps in the readme.txt file I will get this error and I don't know how to reach the correct directory in Quartus software
Error:couldn't read file "scripts/synth.tcl": no such file or directory
Error:"_source scripts/synth.tcl"
Error:"source scripts/synth.tcl"
Mourad
--- Quote Start ---
--- Quote End ---
Sorry, my bad, I did not include one instruction - change directory using the Tcl console. See the readme.txt inlined above.
Please download the zip file again, I modified the synth.tcl script slightly to work properly under 13.0sp1 (the last version that supports Stratix II devices).
Cheers,
Dave
Hello everyone.
I got a Stratix II EP2S60 DSP Development Board, but I couldn't find the cd-rom which contains the software of the development kit. Am i lucky enough to find anyone here having it and willing to send me a copy? my email is steeqa@gmail.com. Thanks and thanks.
