Programmable Devices
21611 Discussions
FPGA as router delay simulmator
Altera staff,
I'm new in this forum and I need your help.
okay, I'm looking for peroforming the following application:
I have a number of devices which communicate to each others through analog signals.
what I'm looking for is to use an FPGA bywhich I can interface my devices.
To be clear, with theyour product I should be able to do:
- routing received signal from one device to another
- delaying some signals in specific instance
- using a software interface to perform the desired specifcation.
- I need at least 10 analog inputs and 3 analog outputs.
Specs:
-The analog signal input frequency is about 24KHz
- the delay range is about 0 to 25µsec
- voltage range is +/- 10V for analog inputs and +-5V for the outputs
my questions:
what's the FPGA type that answers to my applications ?
Best Regards.
well, no FPGAs have analogue inputs - you will need ADCs for that. And I dont think there are many dev boards with that many analgue inputs. So you'll have to build a custom board.
But from a logic perspective its rather simple. The cheaper cyclones or maybe even a max 5 should be ok.
