21615 Discussions
FT2232H write from PC to FPGA not working
I am now using the FT2232H usb chip in FT245 Sync Fifo mode. I tried to write some bytes from PC to FPGA and then read them back. But the following code is not working: what I read back is always 0x55, not what I wrote to FPGA. Here is the code:
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity FTDI_Controller is port( FTDI_RXF_n : in std_logic; FTDI_TXE_n : in std_logic; FTDI_RD_n : out std_logic; FTDI_WR_n : out std_logic; FTDI_OE_n : out std_logic; FTDI_Data : inout std_logic_vector(7 downto 0); CLK_FTDI : in std_logic ); end FTDI_Controller; architecture RTL of FTDI_Controller is begin process(CLK_FTDI) variable rCS: integer range 0 to 2:=0; variable wCS: integer range 0 to 1:=0; variable D_Readed: std_logic_vector(7 downto 0):=x"55"; begin if rising_edge(CLK_FTDI) then --read operations if (FTDI_RXF_n = '0') then FTDI_WR_n <= '1'; wCS:=0; CASE rCS is when 0 => FTDI_OE_n <= '0'; rCS:=1; when 1 => FTDI_RD_n <= '0'; rCS:=2; when 2 => D_Readed := FTDI_Data; when others => rCS:=0; end CASE; else FTDI_RD_n <= '1'; FTDI_OE_n <= '1'; rCS:=0; --write operations if(FTDI_TXE_n ='0') then CASE wCS is when 0 => FTDI_WR_n <= '0'; wCS:=1; when 1 => FTDI_Data <= D_Readed; when others => wCS:=0; end CASE; else FTDI_WR_n <= '1'; wCS:=0; end if; end if; end if; end process; end RTL;
I believe D_Readed needs to be a registered signal, not a variable.
--- Quote Start ---
--- Quote End ---
I have tried to change D_Readed to a registered signal, but the result is the same. I stuck in this problem for a long time.
You can't drive a bidirectional bus in such a simple manner. You need some logic to determine when to drive the bus and when not to.
Try this. I hope it helps and points you in the right direction.library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity FTDI_Controller is port( FTDI_RXF_n : in std_logic; FTDI_TXE_n : in std_logic; FTDI_RD_n : out std_logic; FTDI_WR_n : out std_logic; FTDI_OE_n : out std_logic; FTDI_Data : inout std_logic_vector(7 downto 0); CLK_FTDI : in std_logic ); end FTDI_Controller; architecture RTL of FTDI_Controller is signal D_Readed: std_logic_vector(7 downto 0); signal drive_bus: std_logic; -- Use this to determine control drive of the 'FTDI_Data' bus begin process(CLK_FTDI) variable rCS: integer range 0 to 2:=0; variable wCS: integer range 0 to 1:=0; begin if rising_edge(CLK_FTDI) then drive_bus <= '0'; -- Ensure the bus isnt driven when it shouldn't be --read operations if (FTDI_RXF_n = '0') then FTDI_WR_n <= '1'; wCS:=0; CASE rCS is when 0 => FTDI_OE_n <= '0'; rCS:=1; when 1 => FTDI_RD_n <= '0'; rCS:=2; when 2 => D_Readed <= FTDI_Data; when others => rCS:=0; end CASE; else FTDI_RD_n <= '1'; FTDI_OE_n <= '1'; rCS:=0; --write operations if(FTDI_TXE_n ='0') then CASE wCS is when 0 => FTDI_WR_n <= '0'; drive_bus <= '1'; -- You're writing, so drive the bus... wCS:=1; when 1 => drive_bus <= '0'; -- ... for a bit. Then stop. when others => wCS:=0; end CASE; else FTDI_WR_n <= '1'; wCS:=0; end if; end if; end if; end process; -- Control the data being driven onto the FTDI_Data bus here: FTDI_Data <= D_Readed when drive_bus = '1' else (others => 'Z'); end RTL;
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
Finally I got it working with your tips. Thanks so much, Alex. :)
