Programmable Devices
公告
21615 讨论
Failed during changing the permission "Superloop Example"
名誉分销商 II
2,259 次查看
Hello Friend,
I am trying to implement Ethernet connectivity on my ESDK board without using OS, and for this i am using Superloop example
http://www.alterawiki.com/wiki/superloop_simple_socket_server_plus (http://www.alterawiki.com/wiki/superloop_simple_socket_server_plus
for this i need to first run a script ./create-this-app which is in software_example directory having many other folders.
but during script run it stops after generating few files saying that.
1 chmod: chnaging permission of '/rozipfs_example.tgz" :permission denied
2 chmod: changing permission of '/srozipfs/test_1.txt' " :permission denied
3 chmod: changing permission of '/srozipfs/test_2.txt' " :permission denied
4 chmod: changing permission of '/srozipfs/test_3.txt' " :permission denied
etc.
i have also untar all these files from linux and change permission using "chmod 777 filename" but no gain these error remain their during script run.
How do i come out form this kind of problem.
kaushal
0 项奖励
10 回复数
名誉分销商 II
1,481 次查看
print screen of error's
include.h no such file etc
0 项奖励
名誉分销商 II
1,481 次查看
Had very similar problems regarding permissions trying to run that script on a project located on a network drive mapped to a drive on a PC. Moving the project to the local C drive cleared all such permission problems...
0 项奖励
名誉分销商 II
1,481 次查看
Thanking you for reply, Ok i have put all the directories and archive files in C Drive and again run the script "./create-this-app",
now it generate some files and stuck at point and saying that "no such file or directories" for include.h
0 项奖励
名誉分销商 II
1,481 次查看
Where is 'include.h' located? If it's in either the project directory or _bsp directory it will be found. Those two paths are included in the project by default. If it is elsewhere you will either have to add an include path to your project, specifying the folder it is in, or specify the relative path within your include statement:
#include "../INC/include.h".
Finally, you are using double quotes to specify the include file, not angle brackets - aren't you?
0 项奖励
名誉分销商 II
1,481 次查看
i haven't found any "include.h" file in project directory or _bsp directory or not even my project folder that is superloop_sss_plus_3c120_marvell_11.0sp1
do you have a copy of include.h file ....?
0 项奖励
名誉分销商 II
1,481 次查看
Is Any buddy successfully implement superloop on altera ESDK board...?
as i am facing error's like missing files (include.h ) etc.
0 项奖励
名誉分销商 II
1,481 次查看
I assumed the compiler couldn't find your 'include'h'. I didn't realise you didn't even have one.
If you've downloaded the superloop project then I have to assume the include file you need is in there somewhere. I don't mind having a look if you point me to where you sourced the project...
0 项奖励
名誉分销商 II
1,481 次查看
Hello There,
Thanks for reply.
I have download this superloop example from http://www.alterawiki.com/wiki/superloop_simple_socket_server_plus
and download 20110828_superloop_sss_plus_3c120_marvell_11.0sp1.tgz (http://www.alterawiki.com/uploads/e/eb/20110828_superloop_sss_plus_3c120_marvell_11.0sp1.tgz) as i am using Quartus 11.0 SP1
and unzip the archive using tar -xzf <file name>, then run the script from software_example folder that is ./create-this-app using bash (having gcc4).
at the end of this script run , i got error message (as attached in my previous post on same thread).
i am doing all these stuff on C drive and folder name have no space (as mentioned in alterawiki page)
*Attached is print-screen of bash (Quartus 9.0) using
0 项奖励
名誉分销商 II
1,481 次查看
BeMicro SDK do you mean?
I got it working eventually.....
http://www.alteraforum.com/forum/showthread.php?t=33094&highlight=bemicro+superloop
0 项奖励
名誉分销商 II
1,481 次查看
thanks rob,
will try this out ...
0 项奖励
回复
