21602 Discussions
Fatal Error: Int Divide By Zero
It's driving me crazy. I couldn't figure it out what is the problem. I mean, all versions of quartus 2 (ver 8,9,9.1,9.2,10.0,10.1... trust me I downloaded and tried all)
shows me this one: there is no exception.
*** Fatal Error: Int Divide By Zero
Module: quartus_map.exe
Stack Trace:
0x258e4: GEN_MACHINE_INFO::get_cache_size + 0x3b4 (CCL_GEN)
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off lab1 -c lab1
End-trace
I have no idea what is wrong with mine... It is my laptop setting or something like that?
I would really appreciate it if you give me some solutions to make. Thank you. Hope you're having a great day.
And it's also working perfectly fine in my sister's and mom's laptop, but not mine. I've tried in windowsb7, 8, and 10, none of them work.
Have you tried deleting the db and incremental db folders?
--- Quote Start ---
The db folder in a project directory?
yes. It is an autogenerated folder when you compile a project. Deleting it has been known to fix some crashes.
Just tried it. Didn't work :(
Have you tried running a hardware diagnostic on your system that checks the CPU functionality? Maybe you have a malfunctioning CPU or possibly memory.
Given that you see the problem on all recent versions of Quartus and ONLY on your system I would suspect something specific to your hardware (or software).
