21592 Discussions
First time CPLD use questions - internal pull up resistor and clocking with Max 7000S
I've designed a video game controller using Altera Max 7000s and Quartus 2 using the BDF process.
1-Was I suppose to add a clock? I only have inputs and outputs and logic gates needed in the bdf file.
2-Does the EPM7064SLC4410N have an internal clock that is could use? Does this occur by default?
Logic is pretty simple NAND, NOR, OR, and NOT gates. Pins have been assigned. I assign the JTAG pins to the JTAG functions (tdi, tdo, etc).
3-However I want to double check my understanding of the inputs. I set inputs to VCC. I assume this means the pin is high, kind of like internal pull up resistor. The inputs go to external switches that will ground these pins to indicate low. I assume this doesn't short power to ground, right?
Thanks for making such cool products.
If you only use combinatorial logic, a clock is not strictly required.
However, in a typical design you have a least one register or a few synchronous functions, so you usually do need a clock.
Some CPLD and FPGA have internal clocks available, but they are far from being at precise frequency, since they are generated without a crystal. So, they can be used for very basic clocking, but not for something like driving serial ports or similar functions requiring a stable frequency reference.
No matter setting inputs connecting them to VCC or GND: this is what we common do for test purposes. The CPLD internal pull up resistors are not a problem since they usually have a high value, in the tens-of-kohms range. You only must pay attention to not exceed the I/O input voltage range.
If you only use combinatorial logic, a clock is not strictly required. <-- great
However, in a typical design you have a least one register or a few synchronous functions, so you usually do need a clock. ,<-- None, here just a bunch of NAND, NOR, OR, NOT gates
I'm using Block Diagram / Schematic tool, when I add a input and then right click and go to properties. It allows me to set the 'default value' to either VCC or GND. Is this setting used for anything?
I want inputs and outputs to be pulled high internally. How do I do this?
Ok I found setting on Max V CPLD for Weak Pull-up Resistor" after I customize window in pin planner.
By weak I assume that means like 4.7Kohms or something, right?
I find no such setting for Max 7000S (EPM7064SLC4410N) <--this is the CPLD I want to use as it supports 5v I/O operation.
Does Max 7000S CPLD support internal pull up resistor, or does it need to use an external pull up resistor?
Pull up resistors in FPGA and CPLD are not 'real' resistors. They are implemented with a biased MOSFETs, so their characteristic is dependent on the VCCIO voltage.
Usually the datasheet specifies a maximum sourced current, not the ohmic value which is commonly in the 10k to 100k range; that's why they are referred to as 'weak'.
I never used the Max7000 device and I don't have the datasheet here, so I can't tell you if the pull up feature is available.
I reviewed the datasheet for Max V and it discusses the weak pull resistor, the datasheet for Max 7000S does not mention pull up resistors. This confirms what I saw in Quartus II--> the Max 7000S does not have weak pull up resistor feature. I'll be installing an external pull up resistor on the inputs.
