Programmable Devices
公告
21615 討論
Fixed Point VHDL Support in Quartus
榮譽貢獻者 II
8,898 檢視
I am asking how people have found the synthesis results with the new VHDL2008 package for fixed point. I have created a design that is a cascaded filter simulating a three phase RL load for a motor control application. I haven't synthesized it into quartus yet, but even if it compiles just fine, I am wondering if anyone in the community at large has had any issues with the implementation of these packages in Quartus?
This will be very influential in doing various types of controllers; PI, sliding mode, model reference adaptive control, etc . . .
Thanks, James
library IEEE; use IEEE.STD_LOGIC_1164.all; use ieee.numeric_std.all; use ieee.math_real.all; use ieee.fixed_pkg.all; entity ModelVoltage is port( MCLK : in STD_LOGIC; HRST : in STD_LOGIC; START : in std_logic; VA : in STD_LOGIC; VB : in STD_LOGIC; VC : in STD_LOGIC; DCBUSVOLTS : in STD_LOGIC_VECTOR(11 downto 0); VAx : out sfixed(16 downto -16); VBx : out sfixed(16 downto -16); VCx : out sfixed(16 downto -16); Vn : out sfixed(16 downto -16); IA : out sfixed(16 downto -16); IB : out sfixed(16 downto -16); IC : out sfixed(16 downto -16); DONE : out std_logic ); end ModelVoltage; architecture RTL of ModelVoltage is type stateType is (S0,S1,S2,S3,S4,S5,S6,S7,S8); signal state : stateType; constant Cx: integer := 8; constant Dx: integer := 16; constant R : integer := 16; constant N : integer := 16; constant P : integer := 16; constant M : integer := 40; type abcType is record a : sfixed(R downto -N); b : sfixed(R downto -N); c : sfixed(R downto -N); n : sfixed(R downto -N); nX : sfixed(R downto -N); aR : sfixed(P downto -M); bR : sfixed(P downto -M); cR : sfixed(P downto -M); aV : sfixed(R downto -N); bV : sfixed(R downto -N); cV : sfixed(R downto -N); aVk1 : sfixed(R downto -N); bVk1 : sfixed(R downto -N); cVk1 : sfixed(R downto -N); ak : sfixed(P downto -M); bk : sfixed(P downto -M); ck : sfixed(P downto -M); ak1 : sfixed(P downto -M); bk1 : sfixed(P downto -M); ck1 : sfixed(P downto -M); end record; signal v : abcType; signal i : abcType; constant RecipThree : sfixed(8 downto -8) := to_sfixed(0.333,8,-8); constant Rx : sfixed(8 downto -8) := to_sfixed(0.55,8,-8); constant Ts2 : sfixed(8 downto -24) := to_sfixed(0.0004,8,-24); begin process(all) begin if HRST then v.a <= to_sfixed(0,R,-N); v.b <= to_sfixed(0,R,-N); v.c <= to_sfixed(0,R,-N); elsif rising_edge(MCLK) then if START then if VA then v.a <= to_sfixed(signed(DCBUSVOLTS),R,-N); else v.a <= to_sfixed(-200,R,-N); end if; if VB then v.b <= to_sfixed(signed(DCBUSVOLTS),R,-N); else v.b <= to_sfixed(-200,R,-N); end if; if VC then v.c <= to_sfixed(signed(DCBUSVOLTS),R,-N); else v.c <= to_sfixed(-200,R,-N); end if; end if; end if; end process; VAx <= v.Av; VBx <= v.Bv; VCx <= v.Cv; process(all) begin if HRST then v.n <= to_sfixed(0,R,-N); elsif rising_edge(MCLK) then if state = S2 then v.n <= resize((v.a + v.b + v.c),R,-N); end if; end if; end process; process(all) begin if HRST then v.nX <= to_sfixed(0,R,-N); elsif rising_edge(MCLK) then if state = S3 then v.nX <= resize(RecipThree*v.n,R,-N); end if; end if; end process; /*-------------------------------- Resistive voltage drop --------------------------------*/ process(all) begin if HRST then v.aR <= to_sfixed(0,P,-M); v.bR <= to_sfixed(0,P,-M); v.cR <= to_sfixed(0,P,-M); elsif rising_edge(MCLK) then if state = S4 then v.aR <= resize(Rx*i.ak,P,-M); v.bR <= resize(Rx*i.bk,P,-M); v.cR <= resize(Rx*i.ck,P,-M); end if; end if; end process; process(all) begin if HRST then v.aV <= to_sfixed(0,R,-N); v.bV <= to_sfixed(0,R,-N); v.cV <= to_sfixed(0,R,-N); elsif rising_edge(MCLK) then if state = S5 then v.aV <= resize((v.a - v.aR - v.nX),R,-N); v.bV <= resize((v.b - v.bR - v.nX),R,-N); v.cV <= resize((v.c - v.cR - v.nX),R,-N); end if; end if; end process; process(all) begin if HRST then i.ak <= to_sfixed(0,P,-M); i.bk <= to_sfixed(0,P,-M); i.ck <= to_sfixed(0,P,-M); elsif rising_edge(MCLK) then if state = S6 then i.ak <= resize(((v.aV + v.aVk1)*Ts2 + i.ak1),P,-M); i.bk <= resize(((v.bV + v.bVk1)*Ts2 + i.bk1),P,-M); i.ck <= resize(((v.cV + v.cVk1)*Ts2 + i.ck1),P,-M); end if; end if; end process; process(all) begin if HRST then i.ak1 <= to_sfixed(0,P,-M); i.bk1 <= to_sfixed(0,P,-M); i.ck1 <= to_sfixed(0,P,-M); v.aVk1 <= to_sfixed(0,R,-N); v.bVk1 <= to_sfixed(0,R,-N); v.cVk1 <= to_sfixed(0,R,-N); elsif rising_edge(MCLK) then if state = S7 then i.ak1 <= i.ak; i.bk1 <= i.bk; i.ck1 <= i.ck; v.aVk1 <= v.aV; v.bVk1 <= v.bV; v.cVk1 <= v.cV; end if; end if; end process; IA <= i.ak(16 downto -16); IB <= i.bk(16 downto -16); IC <= i.ck(16 downto -16); process(all) begin if HRST then state <= S0; done <= '0'; elsif rising_edge(MCLK) then case state is when S0 => if START then state <= S1; else state <= S0; end if; done <= '0'; when S1 => state <= S2; when S2 => state <= S3; when S3 => state <= S4; when S4 => state <= S5; when S5 => state <= S6; when S6 => state <= S7; when S7 => state <= S0; done <= '1'; when others => null; end case; end if; end process; end RTL;
0 積分
18 回應
榮譽貢獻者 II
4,623 檢視
Hi James,
I played with the fixed package briefly. Under Modelsim I could use the IEEE packages, but under Quartus I had to use David Bishop's _c.vhdl compatibility packages.
http://www.eda.org/fphdl/
Other that that, they worked fine. (Though my tests were hardly exhaustive).
Cheers,
Dave
榮譽貢獻者 II
4,623 檢視
Dave,
That is excellent feedback. It gives me motivation to synthesize this design and others that I have thought about, and test them in the lab. For filter and controller design I think this will prove most useful. I just wish that Altera paid a little more attention to VHDL versus Verilog. Thanks.
James
榮譽貢獻者 II
4,623 檢視
I have had great results with it (using the 93 compatible versions that is!). I've infered multipliers and RAMs using sfixed and ufixed types without a problem.
Target was an Arria 2.
榮譽貢獻者 II
4,623 檢視
Tricky, That is very good news. I take it you also used David Bishops package for actual compilation under Quartus? Best, James
榮譽貢獻者 II
4,623 檢視
yes, those are the 93 compatible ones. please make an enhancement request for full vhdl 2008 support.
quartus is actually good at inference. I've made it infer rams from constrained integers and used character type as a address aswell (that was just an experiment, not a real design).
榮譽貢獻者 II
4,623 檢視
I have submitted a service request to Altera for full support of the fixed point package in VHDL2008. I will be curious to see what they have to say about this, and will let you know what they say. Thanks, James
榮譽貢獻者 II
4,623 檢視
Tricky, in terms of an enhancement request for Altera, is there a specific channel to go through? I went through my support and it is not working too well. Thanks, James
榮譽貢獻者 II
4,623 檢視
Hi James,
--- Quote Start ---
--- Quote End ---
Do you have an FAE contact, at say Arrow, that you buy parts through? If so, then if you give them your SR number, they can internally apply pressure further up the support hierarchy.
Cheers,
Dave
榮譽貢獻者 II
4,623 檢視
Dave, Thanks for the feedback. I went ahead and corresponded on mysupport, where I had a case opened, and explicitly stated that I wanted an enhancement request for fixed point support in VHDL 2008 within Quartus. They said that they would pass it onto the software team; I also mentioned that it would be nice to have a more direct channel on the website for enhancement requests . . . Since I am new to Silicon Valley I haven't met my FAE's yet, but hopefully will soon. Thanks, James
榮譽貢獻者 II
4,623 檢視
Hi James,
--- Quote Start ---
... I am new to Silicon Valley ....
--- Quote End ---
... ahhh, Mountain View, such nice restaurants ....
If you're also new to California, then make sure to visit Yosemite. If you feel like driving a little further (through to the other side of the park), you can come visit me, and I'll give you a tour ...
http://www.mmarray.org/
Cheers,
Dave
榮譽貢獻者 II
4,623 檢視
Thanks Dave. I will do that, I appreciate it. Best, James
My new VHDL:
California <= std_logic(FPGA_JOBS)
榮譽貢獻者 II
4,623 檢視
Hi, I am using Quartus 12.0 SP1 with MdoelSim Altera Starter Edition
and try to use fixed_pkg.
As you wrote, ModelSim understands very well
but Quartus does'nt.
I had to add the D Bishop package and adapt my use statements ("ieee_proposed")
A little constraint, but not found until I was in this thread.
Maybe for next year, Altera would include fixed_pkg in Quartus
Happy year-end !
榮譽貢獻者 II
4,623 檢視
I have posted an example Quartus design in this thread:
http://www.alteraforum.com/forum/showthread.php?t=37555&page=6&p=155203#post155203
As you comment, you need to use library ieee_proposed to keep Quartus happy :)
Cheers,
Dave
榮譽貢獻者 II
4,623 檢視
I am doing my Final year project including the floating point calculation. Anyone here know how to convert floating point number into integer with using the floating point package float_pkg_c.vhdl ? I already tried with the code below (a simply floating point addition and convert the summation into integer) but it show me this error --> "Error (10454): VHDL syntax error at float_pkg_c.vhdl(4314): right bound of range must be a constant" .Anyone here can help me to solve it? thanks.
Code:
library ieee;
use ieee.std_logic_1164.all;
library ieee_proposed;
use ieee_proposed.fixed_float_types.all; -- ieee in the release
use ieee_proposed.float_pkg.all; -- ieee.float_pkg.all; in the release
entity round is port (
a, b : in std_logic_vector (31 downto 0);
Sum : out integer;
Clk, reset : in std_ulogic);
end round;
architecture RTL of round is
signal afp, bfp, Sumfp : float32; -- same as "float (8 downto 23)"
begin
afp <= to_float (a, afp); -- SLV to float, using afp' range
bfp <= to_float (b, bfp); -- SLV to float, using bfp' range
process (clk, reset)
begin
if reset = '1' then
Sumfp <= (others => '0');
elsif rising_edge (clk) then
Sumfp <= afp + bfp;
Sum <= to_integer (Sumfp,round_inf,true);
end if;
end process;
end RTL;
榮譽貢獻者 II
4,623 檢視
In contrast to IEEE fixed point package, floating point package is effectively useless for logic synthesis because it's not able to generate any pipelining.
You should use the Altera floating point MegaFunctions instead, they provide al operations you want.
榮譽貢獻者 II
4,623 檢視
--- Quote Start ---
--- Quote End ---
But i am using the quartus 2 version 9.0 and altera DE2 board with cyclone 2 device. is it support for megafunction? since i had download the design example of megafunction using my quartus 2 but it said this version is not compatible to open this design example project.
榮譽貢獻者 II
4,623 檢視
When using newer incompatible *.qsf files (e.g. from Quartus 11 or 12) with Quartus 9, a few lines have to be manually deleted. Quartus is telling you which lines are incompatble.
But incompatible example designs hasn't to do with floating point MegaFunctions. They are available in Quartus since long.
榮譽貢獻者 II
4,623 檢視
--- Quote Start ---
--- Quote End ---
Noted. i had tried a simple floating point summation and convert it into integer using megafunction, it's is work. But the problem is i need to round toward positive infinity for my DSP coding but megafunction only support for round to nearest only. Any others way to make it?
回覆
