Flash Memory
Hello. I am using Altera DE2 Board with Flash (1Mb). I want to know how to store data into and read data from flash memory. For example, I want to store 1-10 into the flash. Then, I will read the number 1-10 from the flash memory for addition. Thanks!
Add these header files:
# include "sys/alt_flash.h"
# include "sys/alt_flash_dev.h"
and take a look to the functions available in them.
thanks. but i dont really understand. can i have some sample code? just a simple writing and reading to/from flash.
First of all init the flash device and possibly get extra info about the flash device, like block size:
flash_region *regions; int numRegions; int error = 0; pFlashDevice = alt_flash_open_dev(FLASH_CONTROLLER_NAME); if (pFlashDevice <= 0) error = -1; if (!error) error = alt_epcs_flash_get_info(pFlashDevice, &regions, &numRegions); if (!error) { flash_block_size = regions->block_size; flash_max_addr = regions->region_size; This is for erasing a single block:
alt_epcs_flash_erase_block(pFlashDevice, block_address); This is for writing any data to a previously erased area:
int buf = { 1, 2,3,4,5,6,7,8,9,10 }; rv = alt_epcs_flash_write_block(pFlashDevice, block_address, data_offset_inside_block , buf, 10); Then, read back data with:
alt_epcs_flash_read(pFlashDevice, addr, buf, len);
--- Quote Start ---
i am using cfi, is it the same? besides, my pflashdevice is <= 0. i dunno why. is it sth to do with reset vector as my reset vector is sdram.
why need rv when write data?
where is the data when we read it from the flash? like i want to print out the data.
--- Quote End ---
please help me with the ques in bold. thanks!
This is not mandatory, but recommended to check if data has been written correctlywhere is the data when we read it from the flash? like i want to print out the data.
What's the problem? The buf array contains your data.
Maybe this way is clearer:
int buf[10];
alt_flash_read(pFlashDevice, addr, buf, 10);Remark:
remove epcs_ from the previous post. I copied and pasted from a project using epcs instead of parallel flash and forgot to change function names.
thank you very much
