21611 Discussions
Flash memory without sopcbuilder
Does someone know if is possible using the flash memory without sopc builder?
I try to use it but in data out pin i read nothing.
I've created an entity
entity nuovoflash is
port (
resetgenerale: in std_logic;
clock: in std_logic;
address : out STD_LOGIC_vector (21 downto 0);
data : INout STD_LOGIC_vector (7 downto 0);
ingressi: buffer std_logic_vector (7 downto 0);
uscite : out std_logic_vector (7 downto 0);
chipenable : out STD_LOGIC;
outputenable http://www.alteraforum.com/images/smilies/redface.gif ut std_logic ;
reset : out STD_LOGIC;
writeenable : out STD_LOGIC
end nuovoflash;
The output pins are controlled by a fsm controller.
In the modelsim simulation the signals are good.
The memory should work but it doesn't work.
I've also created an interface entity to separate the data inout in data in and data out but i don't read the output bit from the oscilloscope when i connect the board to it.
where do you want to read the answers ?
you're double posting your questions.
Sorry.
Answer me to the other thread.
This is the link
http://www.alteraforum.com/forum/showthread.php?t=19156
