21615 Discussions
Floating point megafunctions
Has anyone had a problem with the altera's mega functions?
My 1st output when I used the divide is always 3fdfffc0.
And I always enable as soon as I store my 1st input.
Also, just to confirm 'dataa' <= is the numerator
How is it parametrized and what was the numerator (dataa) and denominator (datab)? How many cycles after the inputs are committed are you waiting for the output?
The pdf does not explain whether the denominator is datab or dataa.
I used 6 cycles.
and I am using single precision
From the pdf: "dataa[] Yes
Numerator data input. The MSB is the sign bit, the next MSBs are the exponent, and
the LSBs are the mantissa. The size of this port is the total width of the sign bit,
exponent bits and mantissa bits."
Here is a handy webpage I use when I'm working on floating point numbers: http://www.h-schmidt.net/floatapplet/ieee754.html
Thank you for the quick reply,
But my answers do not match.
I had y= a/b
a= 81
b= 76.6
Y= 1.057
but my answer is always 3fdfffc0 at the 1st output (which is 1.74999237060546875e0
I dont know what I am doing wrong.
I wait for 6clock cycles before I store my values
Are you simulating this design? If not then I would recommend doing so just in case the enable bit is not timed correctly.
Attached is a snapshot of my simulation.
I think the enable is fine because datab comes in at the same time as the enable=1
That is odd, I would have expected 0x42c20000 / 0x42994000 = 0x3fa20930. Copy and paste you instantiation of the divider into this post, maybe there is something incorrectly set.
Hi, I hope this makes sense, I can explain it if not. Thanks again
/* dividing time*/
if(en_divi)
begin
fcnt7<=fcnt7+1;
if (fcnt7>4) // waS 4
begin
if(Add3>=MxN-1)
begin
memBD_f32[Add3]<=div1_f32;
Add3<=0;
en_divi<=0;
en_divi2<=1;
end
else
begin
Add3<=Add3+1;
end
end
end //end of en_divi
if(en_divi2)
begin
d2_en<=1;
if(Add3>=MxN-1)
begin
tempA2<=memA_f32[Add3];
tempX<=memX_f32 [Add3];
Add3<=0;
end
else
begin
Add3<=Add3+1;
fcnt8<=fcnt8+1;
end
if (fcnt8>5) // output latency is 6
begin
if(Add4>=MxN-1)
begin
memTD_f32[Add4]<=div2_f32;
Add4<=0;
en_divi2<=0;
d2_en<=0;
end
else
begin
Add4<=Add4+1;
end
end
end //end of en_divi2
divi_f32 divi_bmexp(reset,en_divi,CLK,max_f32,Xop_f32,div1_f32); //bottom
divi_f32 divi_tmexp(reset,d2_en,CLK,tempX,tempA2,div2_f32); // top divide
I mean the instantiation of altfp_div not the logic around it.
--- Quote Start ---
divi_f32 divi_bmexp(reset,en_divi,CLK,max_f32,Xop_f32,div1_ f32);//bottom
--- Quote End ---
I added the other part to show when I start storing the values
Ok I guess you used the megawizard GUI to output the HDL. Do you have an instantiation file that shows how divider was parameterized? You'll probably find it in whatever file contains the "divi_f32" module.
Sorry for the late reply. Attached here
Looks like it is setup correctly. Perhaps you are running into this (but I doubt it since I think the simulation would fail to compile): http://www.alteraforum.com/forum/showthread.php?t=22653
I recommend opening a service request on this one: http://www.altera.com/mysupport
