21611 ディスカッション
Fpga speed
名誉コントリビューター II
1,202件の閲覧回数
hi
can any one tell me what is the maximum speed that todays FPGA's can support
0 件の賞賛
3 返答(返信)
名誉コントリビューター II
381件の閲覧回数
no.
It depends on what you are trying to achieve.
Todays FPGAs contain high speed serializer, that can transmit and receive data with multiple Gigabits per second. But that's probably not what you are after.
Maximum speed largely depends on the design; buffer-to-buffer switching speed is much higher than any useful logic implementation. So, the raw switching value does not say anything.
For typical designs, Altera has a paper that compares NIOS implementation across different devices. Maybe altera's nios ii performance benchmarks (http://www.altera.com/literature/ds/ds_nios2_perf.pdf) could be a start?
名誉コントリビューター II
381件の閲覧回数
I am running significant processing up to and over 400 MHz with 128b datapath in SIVGT (highest speed grade). Not bad.
Jerry
名誉コントリビューター II
381件の閲覧回数
51,2Gbit? Nice :)
返信
