21615 Discussions
Frame Buffer Design
Hello All,
I am designing a Custom fram buffer which will have three AV st source ports, which will be able to be enabled and disabled as pleased. But have come to a problem in the method how you manage the write and read ports sucessfully.
any ideas?
What I actualy need is a method to be able to send a video stream to video out and some times if need be record the stream. Hope to hear from you all... thanks
regards nadeem
