Programmable Devices
21611 Discussions
GHRD interrupts
I would like to use the standard GHRD design to handle interrupt. It looks like the pushbutton interrupts are enabled in the Qsys design.
I have no idea how to register a callback in Linux code on one of these interrupt lines.
Can anyone help with some example Linux code that works with the GHRD?
I think you'd better write a linux driver for the button!
I have the Arrow SoCkit, and I have been struggling with this for a while. I'm digging into the device tree for the arrow board posted on rocketboards, and I found an entry for the gpio's.
agpio0: gpio@0xc0000000 {
compatible = "altr,pio-1.0";
/* Register base 0xff200000 is for a light-weight bridge */
reg = <0xff200000 0x10>;
width = <32>;
/* There are 64 interrupts from the FPGA start at 72, so 45 has to be wrong */
interrupts = <0 45 4>;
interrupt-controller;
# interrupt-cells = <1>;
gpio-controller;
# gpio-cells = <2>;
level_trigger = <0>;
I verified this is what the Linux kernel sees by looking in the folder at /proc/device-tree/soc/gpio@0xc0000000
I'm worried about the comment : /* There are 64 interrupts from the FPGA start at 72, so 45 has to be wrong */
I wonder why that has to be wrong?
This looks different from the Altera boards device tree entry, which is:
button_pio: gpio@0x100c0 {
compatible = "ALTR,pio-13.0.1", "ALTR,pio-1.0", "altr,pio-1.0";
reg = < 0x000100C0 0x00000010 >;
interrupt-parent = < &hps_0_arm_gic_0 >;
interrupts = < 0 41 1 >;
width = < 2 >; /* width type NUMBER */
resetvalue = < 0 >; /* resetValue type NUMBER */
level_trigger = < 0 >; /* embeddedsw.dts.params.level_trigger type NUMBER */
# gpio-cells = < 2 >;
gpio-controller;
}; //end gpio@0x100c0 (button_pio)
This entry has quite few differences from the arrow version.
I have tried following the example here: C:\altera\13.0sp1\embedded\examples\software\Altera-SoCFPGA-Push-Button-Linux-GNU.tar.gz
I was able to build the gpio-interrupt driver in the example. I used the yocto project kernel headers for the altera board to build against. (Not sure if this was the right way to do this.)
For the arrow board, when I insert the altera-gpio.ko kernel module, ( with 'modprobe gpio_altera'), I find gpiochip224 in /sys/class/gpio.
The next step I did was insert the gpio-interrupt kernel module I built from the example with the command 'modprobe gpio_interrupt gpio_number=224'
So I look at /proc/interrupts and I see this:
CPU0 CPU1
525: 123056 121886 GIC twd
648: 1 0 GIC eth0
656: 1 0 GIC dwc_otg, dwc_otg_pcd, d
667: 2280 0 GIC dw-mci
679: 0 0 GIC ff705000.spi
682: 0 0 GIC dw_spi0
684: 0 0 GIC dw_spi1
686: 0 0 GIC ffc04000.i2c
687: 0 0 GIC ffc05000.i2c
690: 6879 0 GIC serial
697: 9 0 GIC timer2
752: 0 0 altera-gpio (null)
IPI0: 0 0 CPU wakeup interrupts
IPI1: 0 0 Timer broadcast interrupts
IPI2: 1127 1196 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 1 2 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
Err: 0
There is an entry for the altera-gpio interrupt, but it does respond when I push the button (No updating /proc/interrupts, and no message in 'dmesg')
The '(null)' after the interrupt is concerning.
Any help is appreciated.
Hi ecullert
I have writen a hps gpio interrupt driver with kernel-3.8. I build the driver within the kernel and it works.
I get the kernel source from http://www.rocketboards.org/foswiki/view/projects/sockitlinarolinuxdesktop
In the dts I just add myself code
gpio1: gpio@0xff709000 {
compatible = "key";
reg = < 0xff709000 0x00001000 >;
interrupts = <0 165 4>;
The interrupt number in dts is 32 less than the number in GIC
The I write my own driver (initial the driver and register the interrupt in kernel)
This driver just uste the gpio interrupt but not fpga interrupt
I hope the information be helpful for you!
TO_BE_DONE
Can someone please give some help on how to actually use the interrupt. I have a FIFO setup connected the light weight avalon master. The interrupt from the FIFO is connected to the HPS.
But how do I set up the device tree.
I read up somewhere to generate the device tree file from the sopcinfo file. I tried doing this but I got the following response.
"Master and slave interfaces for the Transparent bridge in fifo_0 of type altera_avalon_fifo have different types."
Any thoughts?
Jack
@ecullert
Thank you for your very detailled help.
I have done a "make" with linux-altera-3.7.
Everything works fine in my virtual machine but not on my Evaluation Board.
The Problem:
I get an error for "insmod gpio_interruot.ko" because I should use kernel version 3.8.0.
Is there an altera-linux-3.8?
I have not found anything on Google.
Michael
As far as I can tell, the altera yocto source package is still on 3.7. You could build the 3.7 Linux and do your testing unless there is a reason you need 3.8.
The following webpages should get you through the entire process.
http://www.rocketboards.org/foswiki/documentation/gsrdgettingstartedyocto
http://www.rocketboards.org/foswiki/documentation/gsrdsdcard
Thanks a lot! :-)
