has anyone constrained GMII transmit interface? As you know, GMII has two transmit clocks: one input clock - I'll call it mtx_clk_i - used in MII mode (10/100 Mbps) and one output clock - gtx_clk_o (generated in the FPGA) - used in GMII mode (1000 Mbps). Internally the logic operates on a multiplexed clock between the two mentioned. I could not find an example of how to constrain output delays with respect to an input and an output clock, with different frequencies. The input clock: 2.5 Mhz or 25 Mhz The output clock: 125 MHz Thanks!Link Copied
