21611 Discussions
SRAM verification error afte change LVDS pins
I use a SGDMA to stream a Frambuffer from SRAM to Display via LVDS
when e put a second LVDS Display to the same pins, i got a SRAM verification error during softwaretransfer from NIOS IDE via jtag.
I don't see the relationship between FPGA-LVDS (3R) pins, and the read-write process of SRAM.
Do you know, how i kann find the cause of this problem?
It may be a signal integrity problem. If the design was changed, also a timing issue.
ok, thanks.
but, what can i do agains signal integrity problems?
i have to use this "time Quest" analyser to found/fix the problem?
